X-pipe
Old Mar 13, 2003 | 11:15 AM
02MillenniumVette's Avatar
02MillenniumVette
Default X-pipe
Whats the best X-pipe to get and about how much is it? Thanks in advance.
Old Mar 13, 2003 | 11:56 AM
jmzvet's Avatar
jmzvet
Default Re: X-pipe (Corvette_ZO6)
I've seen them from about $90 to $300. The $90 one is small and welds in and the ones about $250 bolt in.
Old Mar 13, 2003 | 05:41 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Veteran: Coast Guard
Senior Member
Cruise-In V Veteran
The main one you will see are the ones by Corsa, Bassani, and Magnaflow. I looked around for a long time before I got one, and if you look at all three of them side by side, you can clearly see that the Magnaflow is the straightest and best flowing X-Pipe. You can get a good deal on one from Shawn at the LAPD, a forum vendor. :cheers:
Old Mar 13, 2003 | 05:49 PM
pewterhdtop's Avatar
pewterhdtop
Default Re: X-pipe (Craig2000)
:iagree:
The only drawback to the Magnaflow is the slag that the manufacturer left in the tubes. I cleaned it up prior to installation.
Old Mar 13, 2003 | 06:19 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Corvette_Z06,
Look into the x-pipe made by Magnaflow.
You can see the pics of all the x-pipes side by side on our website at: http://www.TheLAPD.com
If you have any questions in regards to x-pipes, please let us know.
Thanks!
Shawn
Old Mar 13, 2003 | 06:52 PM
geck's Avatar
geck
I'm thinking about an X pipe also for my 02 6spd vert. Will it help cut down on the popping I get when I decelerate and more importantly what will it do to the sound of my quad tip stingers? If it kills the agressive sound forget about the X pipe.
Old Mar 13, 2003 | 07:05 PM
X2R&R's Avatar
X2R&R
Default Re: X-pipe (geck)
Does the magnaflow bolt right in on a stock car or is there cutting and welding required?
Old Mar 13, 2003 | 07:24 PM
BlazeSkywalker7's Avatar
BlazeSkywalker7
Default Re: X-pipe (X2R&R)
it bolts on, but you have to cut the stock exhaust
-rich
Old Mar 13, 2003 | 07:53 PM
Highroller's Avatar
Highroller
Default Re: X-pipe (L.A.P.D.)
Corvette_Z06,
Thanks!
Shawn
Which one does the best job of ridding the exhaust of the jingling noise? :withstupid:
Old Mar 13, 2003 | 08:24 PM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
will a X pipe cut the resonance down?
Old Mar 14, 2003 | 10:17 PM
MagRedSkull's Avatar
MagRedSkull
Default Re: X-pipe (rockgt302)
A x-pipe will not help resonance.
Old Mar 14, 2003 | 11:38 PM
ndirishr1's Avatar
ndirishr1
I'm running a Bassanti and it was $299. I chose it because I thought it was a better design and higher quality than the others like Corsa that I had seen.
Old Mar 15, 2003 | 01:57 AM
Mavrick's Avatar
Mavrick
You can't go wrong with either of the main three. I chose the Magnaflow.
I'd check out West Coast Corvette for a great price.
Old Mar 15, 2003 | 10:48 AM
BlueDream's Avatar
BlueDream
I originally had the Borla quad-tip without changing the X-pipe and had a lot of popping and gurggling on deceleration. Just this week I installed the Magnaflow X-pipe (thanks for the recommendation from Shawn at LAPD).
The X-pipe didn't eliminate all of the popping and gurgling but cut it down by about 80 or 90% which made it much more tollerable (this is my daily driver). I won't say it necessarily quieted it down for cruising but it made it MUCH, MUCH smoother for cruising and generally enjoying. But when you step on it, the WOT experience and sound is still there and still attracts a lot of attention.
I know everyone has their own opinions. Just wanted to share my experience on the subject. I would recommend the X-pipe.
:seeya
Old Mar 15, 2003 | 11:06 PM
AN1313's Avatar
AN1313
:auto:
[Modified by AN1313, 10:36 PM 3/19/2003]
To X-pipe
