Alignment After Lowering???
Old Mar 15, 2003 | 11:49 AM
LANZ06's Avatar
LANZ06
Default Alignment After Lowering???
If I lower my 99 FRC do I need to get an alignment afterwards??
Old Mar 15, 2003 | 11:50 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Alignment After Lowering??? (LANZ06)
:yesnod:
Old Mar 15, 2003 | 12:11 PM
99C5Richie's Avatar
99C5Richie
Drive it around for atleast a week before getting the alignment to really let it settle... :thumbs:
Old Mar 15, 2003 | 01:50 PM
Crushinator's Avatar
Crushinator
Default Re: Alignment After Lowering??? (99C5Richie)
And if you lower it too far, you may have a hard time finding an alignment shop that can get your car on the rack. :mad
Old Mar 15, 2003 | 02:06 PM
LANZ06's Avatar
LANZ06
Thanks guys. I love the Forum.
Old Mar 15, 2003 | 02:12 PM
99C5Richie's Avatar
99C5Richie
Default Re: Alignment After Lowering??? (Nat02Z06)
Yeah, that happened to me too... although it was kinda funny to watch... 1 service tech to get it on the lift, 2 service techs to do the actual alignment and lastly 4 service techs to push while lifting the rear end of the car to get it off the lift... :D
[Modified by 99C5Richie, 11:13 AM 3/15/2003]
Old Mar 15, 2003 | 02:24 PM
C5GARY's Avatar
C5GARY
Richie,
1. Where did you get it aligned?
2. How good a job did they do?
3. Did they give you before/after readings? If so, I am real curious what they were.
4. Did you notice the difference?
5. And if you don't mind, how much did it cost? (we are local)
I have been thinking I should get mine aligned, I lowered to the bottom
of the stock bolts a year and a half ago.. it feels better than before and the
tire wear improved too.
Gary
Old Mar 15, 2003 | 03:02 PM
GaryZ06's Avatar
GaryZ06
I lowered mine all the way down on the stock bolts.I drove for about 300 miles then went to my dealer for the alignment.My car went on their rack without a problem....they do have some long boards if your car is really low. :D
Old Mar 15, 2003 | 03:32 PM
99C5Richie's Avatar
99C5Richie
Default Re: Alignment After Lowering??? (C5GARY)
Hey Gary,
1) Wheel Works up here in Concord, CA
2) On a scale of rate 1 - 10, (10 being the best) I give them 7 at best.
3) Yes, they show before and after specs, Not sure if I've still got the sheet, but I'll let you know if I find it... nonetheless, I had them do oem C5 specs. They tried to hit all the specs I asked for but couldn't... but I do know they tried. They didn't mind me standing there for the hour watching them either.
4) Well, when I lowered my ride, I couldn't get the lower A-Arm to drop, so I had to drop the upper A-Arm and disconnected the tie-rod end bolt... that really messed up my alignment... so, yeah, I did notice a differance...
5) Of course, I don't mind... I paid about $175ish, I got the customary BS markup on that it's was lowered quite a bit... but oh well, at least I knew the cost before driving over there....
Next time, I'm thinking of going up to Roseville and have C5Stein's shop do the alignment... Mark knows his stuff....
:yesnod:
Old Mar 15, 2003 | 05:16 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Re: Alignment After Lowering??? (GaryZ06)
Can you explain how you lowered the car? Do you mean that you didnt have to buy any kit or springs? How is the ride and how do I do it? How far is the drop? Thanks
Old Mar 15, 2003 | 05:24 PM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
Default Re: Alignment After Lowering??? (pewter99)
:confused: :confused: Are you sure? I had my lowered on the stock bolts, It was done by THE VETTE DOCTORS, and I was told I don't need the alignment.
Old Mar 15, 2003 | 07:58 PM
FlamerF1's Avatar
FlamerF1
Default Re: Alignment After Lowering??? (c5edko)
I've lowered 4 cars and the alignment is effected very little, but you should have it checked. better safe than ruin some costly tires.
Old Mar 15, 2003 | 08:05 PM
SnowyATX's Avatar
SnowyATX
I didn't align my FRC after lowering about 1/2".....the front tires wore really bad on the inside....just ditched them last week for the SZ50's and had it aligned....they had to use some 2x12's to get it on the lift :D
Old Mar 15, 2003 | 08:58 PM
GaryZ06's Avatar
GaryZ06
Default Re: Alignment After Lowering??? (ccajun4real)
My dealer did it for me...To lower a Vette all you do basically is turn a bolt.If you want to lower the car more you can buy longer bolts.The ride is slightly harder but not harsh at all.It was lowered probably just over an 1-1 1/2.It did need to be aligned after...
[Modified by GaryZ06, 9:05 PM 3/15/2003]
Old Mar 16, 2003 | 12:02 PM
14car's Avatar
14car
Default Re: Alignment After Lowering??? (PewterC5)
I am truely baffled that a so called sports car like my Z06 would need to be aligned after dropping less than 1 inch........If the camber gain and bump steer come into affect at less than 1" of travel enough to cause need for a re-alignment.......man i'm sellin this peice of crap.
Old Mar 17, 2003 | 12:19 AM
Ricksc5's Avatar
Ricksc5
:yesnod:
99C5Richie, This is C5stein, over visiting Rick and using his computer,
Thanks for the good words. We work really hard to make alignments work for the way each of you guys (&girls) drive your car. We have electronic scales for those of you looking for the most accurate setup and have laser alignment equipment that many of the Mascar and ALM teams use to setup their cars. I've been setting up Road Race, Drag Race and street car suspensions for 20 years.
The best news of the day is that we have been accepted as a Corvetteforum Tuner and will start our forum support the first of next month. :cheers:
Mark C5Stein
Motor Sport Image & Performance
Sacramento, CA
Mark@motorsportimage.com
[Modified by Ricksc5, 5:23 AM 3/17/2003]
Old Mar 17, 2003 | 12:35 AM
99C5Richie's Avatar
99C5Richie
Default Re: Alignment After Lowering??? (Ricksc5)
...The best news of the day is that we have been accepted as a Corvetteforum Tuner and will start our forum support the first of next month.
:hurray: :hurray: :hurray: Congratulations!!!! on becoming a supporting tuner!!!!
To Alignment After Lowering???
Old Mar 17, 2003 | 08:10 AM
PalmettoVetteMan's Avatar
PalmettoVetteMan
Or four short boards. :lol:
:cheers:
Old Mar 17, 2003 | 08:19 AM
PalmettoVetteMan
Default Re: Alignment After Lowering??? (14car)
Most drops using the factory bolts range from 1 3/8 to 1 5/8. You don't HAVE to have it aligned, but most people don't want to risk excessive wear on tires. The ride might be a little harsher, but probably more noticable in a coupe with run flats on it.
You own one of the premier production sports cars on the planet, and need to understand that if you modify it you should completely accomodate for that modification to preserve the performance of the car.
If you think the Z-06 is a piece of crap, you're probably better off to sell it to someone who will appreciate it. Just my .02 Good luck either way.
:cheers:
Old Mar 17, 2003 | 08:21 AM
PalmettoVetteMan
:hurray: :hurray: :thumbs: :cheers:
