Spark plug change?
Old Mar 30, 2003 | 09:51 PM
wtlytng's Avatar
wtlytng
Default Spark plug change?
I would like to change spark plugs on my 99 myself, but I here you guys go on about how difficult it is and I’m wondering if there is any “best way to do it” advice out there?
I don’t even know how to get to them.
All plugged up.
:sad:
Old Mar 30, 2003 | 10:01 PM
speedyc5's Avatar
speedyc5
Default Re: Spark plug change? (wtlytng)
All plugged up.
:sad:
Nothing personal wtlyntg, but if you don"t know how to get to them, I would sub this job out :D :D :D
On the otherhand I love the text in you SIG :hurray: :hurray: :hurray:
Old Mar 30, 2003 | 10:17 PM
wtlytng's Avatar
wtlytng
Default Re: Spark plug change? (speedyc5)
Thanks, I knew I would get that reaction from someone. No offense meant, none taken.
I really would like to do this job myself though, I have all the tools and know how to use them I just never bothered to look for the plugs yet as I have only had this car a few months and haven't looked at the engine much.
Non plugged.
:sad:
Old Mar 30, 2003 | 10:19 PM
MyFirst's Avatar
MyFirst
It's really a pretty self-explanatory job. You take off the fuel rail covers and the spark plug wires, find the appropriate socket and drive and take out the plugs. It is really not a difficult job at all.
Old Mar 30, 2003 | 10:26 PM
wtlytng's Avatar
wtlytng
Default Re: Spark plug change? (MyFirst)
I was wondering what those fuel rail covers covered.
If that’s all there is to it then it should be no problem for me to change them.
Thanks. :)
Unplugged. :seeya
Old Mar 31, 2003 | 02:19 AM
MyFirst's Avatar
MyFirst
The fuel rail covers are really just a cosmetic thing since there are a number of wires under them and the oem valve covers are not to exciting to look at (just look at any LS1 Trans Am or Z28/SS). I was a little hesitant about doing it myself, but once I took the fuel rail covers off (no special tools required, just gently pull them off) I saw how easy it really was. You may need an extension for the drivers side rear plug. Don't forget to use a little never seeze to ensure that they'll come back out and don't overtork them. Good-Luck.
Old Mar 31, 2003 | 11:13 AM
99C5Richie's Avatar
99C5Richie
Here's a DIY from the Tech tips section...
https://www.corvetteforum.com/techti...ID=7&TopicID=1
The number 7 plug is PITA... but it just take patience... Investing into a snap-on swivel sparkplug socket worked for me...
:cheers:
Old Mar 31, 2003 | 11:47 AM
Lil Red's Avatar
Lil Red
Go for it, you can do it! :cheers:
Old Mar 31, 2003 | 11:52 AM
wtlytng's Avatar
wtlytng
Default Re: Spark plug change? (99C5Richie)
Hey, thanks for turning me onto that info.
I'm new to the forum and haven’t found all the goodies yet.
:steering:
Old Mar 31, 2003 | 01:13 PM
JNS's Avatar
JNS
St. Jude Donor '06-'09
Is there really any big advantage in changing the stock plugs to something like the NGK TR55 plugs?
Thanks.
Old Mar 31, 2003 | 01:21 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
I just undertook this job with the help of my friend Bill (Bowryboy) this weekend.
It was tough (I had to use my daughter (smaller) to help a couple time) but overall very gratifying to start that car up and he it run again without any audible problems.
It took me 1 hour 45 minutes but next time will be less. He does it in half hour now.
Once you figure where to place every thing you are golden.:) :yesnod:
Link here for my post http://forums.corvetteforum.com/zerothread?id=525303
[Modified by REDGAR, 1:22 PM 3/31/2003]
Old Mar 31, 2003 | 01:24 PM
99C5Richie's Avatar
99C5Richie
Default Re: Spark plug change? (JNS)
I switched over to the NGK TR55 coppers and used the default gap the NGK's came with... I think they're 0.57 or 0.55.... can't remember. Anyway, I definately noticed an improvement... The better combustion made it drive like wild banshee under the hood.
:thumbs:
To Spark plug change?
