Need interior driver door panel!
Old Apr 1, 2003 | 08:55 AM
frdracfan's Avatar
frdracfan
Default Need interior driver door panel!
I am looking for a driver door panel (interior) in black. I have a 97 but I think any c5 will work. Has anyone had the problem of the panel bubbling up around the arm rest? Any fix?
Old Apr 1, 2003 | 09:29 AM
chuckster's Avatar
chuckster
Default Re: Need interior driver door panel! (frdracfan)
Common Problem....Just had both my panels replaced..
You may want to try an Syringe filled with Crazy glue and shoot it under there.. Then put some even pressure on it.. Like a rolled up towel or something...
I bet a local Trim shop could fix it using that idea...
Old Apr 1, 2003 | 11:05 AM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Look to the left column of this page for forum vendors and find Gene's Kar Shop. If anyone can find you a used door panel in good shape, it is Gene!
And yes, the year doesn't matter as you will use all your own internals (switches, etc)
To Need interior driver door panel!
