Wheel Sensor Problem! Help
Old Apr 14, 2003 | 07:55 PM
R BONUS's Avatar
R BONUS
Default Wheel Sensor Problem! Help
Bought new wheels and had Discount Tire mount new tires on them. :smash:
They broke one of my wheel sensors and replaced it before they told me about it. That part was ok, but I am not sure they got the right one. :confused: The manager told me it was a little bigger than the other sensors and now that sensor isn't working with the computer. Is there a learning procedure to go through when you replace a sensor.
Anybody had any experience with this problem?? :cheers:
Thanks, Jim
Old Apr 14, 2003 | 08:05 PM
bandit_99's Avatar
bandit_99
Default Re: Wheel Sensor Problem! Help (R BONUS)
There is a re-learn that must be done. It can be done with a large magnet and following the instrucs on the DIC.
However, they may have gotten the wrong sensor. The sensors for years 97-00 and 01 and newer (I believe this is the breakdown...if I'm wrong, somebody will chime in) are diferent. They may have gotten the wrong sensor. One way will tell for certain...get a big magnet and try to get the new sensor to register on the DIC.
Good luck.
Dave
[Modified by bandit_99, 7:15 PM 4/14/2003]
Old Apr 14, 2003 | 08:09 PM
99C5Richie's Avatar
99C5Richie
Default Re: Wheel Sensor Problem! Help (bandit_99)
:iagree:
Old Apr 14, 2003 | 09:40 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
it sounds like the wrong sensor.
the 01- 03 sensors are smaller then the 97-00 sensors.
you need to check with discount tire and find out the part # of the sensor they installed and then check that # at the dealership.
Old Apr 14, 2003 | 10:01 PM
IM4A2Z's Avatar
IM4A2Z
Default Re: Wheel Sensor Problem! Help (ROCKnROLL)
Relearn Procedure http://service.gm.com:8083/gmtechlin...2e.html#story6
Old Apr 14, 2003 | 11:11 PM
R BONUS's Avatar
R BONUS
Default Re: Wheel Sensor Problem! Help (IM4A2Z)
Thanks for the replys guys! It sounds as if Discount tire put the wrong sensor in, since the already told me it was bigger than the other three.
I read the relearning procedure, and my understanding is you have to relearn all wheels, but where do you get one of those funny loking magnets?? :confused: :cheers:
Thanks, Jim
Old Apr 14, 2003 | 11:16 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
GM PART # 25731358
GM LIST: $80.93
OUR PRICE: $46.13
DESCRIPTION: SENSOR (NUT NOT INCLUDED)
SEE PART NUMBER 25708165 FOR THE MOUNTING NUT FOR THIS SENSOR
Above is from GM Parts Direct for the 02 sensor. Make sure this is the part number they installed.
Old Apr 14, 2003 | 11:17 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
________________________________________ ________________________
Any half way decent magnet will do.
Old Apr 15, 2003 | 01:23 AM
twincam47's Avatar
twincam47
Default Re: Wheel Sensor Problem! Help (vette#one)
:iagree:
I use an old speaker magnet...................
Old Apr 15, 2003 | 04:35 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I read the relearning procedure, and my understanding is you have to relearn all wheels, but where do you get one of those funny looking magnets?? :confused: :cheers:
Thanks, Jim
You have speakers in your door panels and in the rear, breakout and rip up door panel in an emergency! :lol: :lol:
Old Apr 15, 2003 | 08:47 AM
bandit_99's Avatar
bandit_99
Initially, I thought the magnet had to be very large/powerful. I couldn't seem to find anything in that description, so I bought the largest magnet home depot had on their shelf...it was well less than $5, and that did the trick. It was not nearly as big as I thought I would need. The relearn process requires you do it to all 4 tires I believe, but it only takes a minute. :yesnod:
:thumbs:
[Modified by bandit_99, 7:48 AM 4/15/2003]
To Wheel Sensor Problem! Help
