HUD question - help
Old Mar 6, 2005 | 04:51 PM
Larrys60's Avatar
Larrys60
Default HUD Question
Originally Posted by vader1
I have a similar problem. I set the hud with the gas gage, MPH and tach. When I come out the next morning the gas gage is replaced with the oil gage.
No matter what I do, it always come back to the oil.
I took it in and was told that the hud has no memory.
This is an old post, but does anyone know how the problem is resolved?
Is it a battery issue?
Old Mar 7, 2005 | 09:06 PM
Grand Slam's Avatar
Grand Slam
Originally Posted by Richin Chicago
Low voltage on starting will place the HUD in default which is oil level etc. Also your DIC will return to the odometer no matter where you had it set.
Classic low voltage symptoms. Check your battery and look for leakage. If leakage, clean the battery tray and wiring under it.
Old Mar 7, 2005 | 09:16 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
My HUD actually went haywire on me. Everything lit up all at once, then it went out, every now and then it would work but it would get bright then dim. I took it in and they replaced it. And just think that is the only option I did not want! Figures, the first thing to go wrong
To HUD question - help
