Car will not start!
Old Apr 25, 2003 | 10:15 PM
urpow's Avatar
urpow
Default Car will not start!
Ugh,
Hey I need help... car won't start... seems like battery is dead (cabin lights will not go on when the door opens).
Is there anyway I can verify or/and rememdy this? (Got a trip tomorrow)
Thanks!
Old Apr 25, 2003 | 10:42 PM
Miaugi's Avatar
Miaugi
Default Re: Car will not start! (urpow)
...Is there anyway I can verify or/and rememdy this? (Got a trip tomorrow)...
Check battery connections. If there on tight, maybe a charge might bring it back. If not, new AGM battery might be in order. Good luck!
Old Apr 25, 2003 | 10:52 PM
luvinc5's Avatar
luvinc5
Ugh,
Try connecting a battery charger. If you have lights, your battery is gone.
Old Apr 25, 2003 | 11:43 PM
Dave68's Avatar
Dave68
If you have a charger, hook it up and see if the battery accepts a charge. If it does, you may have left a door ajar. If it doesn't, then the battery is probably shot.
Now if you don't have a charger, you might want to take the battery to the dealership to have it checked. After all, if it is still covered by the warranty, you could end up with a new one. If the warranty has expired, a better replacement for a standard lead-acid is the leak and vibrationproof ACDelco AGM battery.
Good luck.
To Car will not start!
