Differential Leak???
Old May 9, 2003 | 01:21 AM
AZGASSER's Avatar
AZGASSER
Default Differential Leak???
I took my Vette into the dealer for the standard GM oil change and check up (Dont flame me for this). Any way, when I got home I noticed a silver dollar sized area of fluid/oil under the differential. I cleaned it up, checked the plugs all tight, no visible fluid from the seals, and no more fluid this morning. Today after a quick run to the coffee shop and some errands, came home parked and had two drop of fluid in the same place again. Ran it by some Vette friends and they felt that my spirited driving :auto: may have thrown some diff oil out the top of the diff. Any one here, heard of that before or am I missing something else. I really dont want to take it back to the dealer unless necessary. This is a new Getrag 3.73 rear end with about 600 miles or so on it. Thanks! :seeya
Old May 9, 2003 | 06:28 AM
JCR's Avatar
JCR
Default Re: Differential Leak??? (AZGASSER)
GM has had a lot of problems with the left side cover "o" ring and axle seal. Check this area..
Old May 9, 2003 | 06:34 AM
vettenuts's Avatar
vettenuts
Default Re: Differential Leak??? (JCR)
Sounds like it's not the original factory unit. You may want to pull the top plug and check for overfill. This will cause it to push it out the vent.
Old May 9, 2003 | 09:03 AM
keith5's Avatar
keith5
Active Streak: 90 Days
Had the exact problem on my '98. My Corvette Tech at local dealership identified the problem on several of the Vettes he services. He wrote a GM service bulletin fix for it that all dealerships can access.
It is a single cover plate bolt that seeps. Not the o-ring ,or a crack, or overfill,
or even hot expanded oil venting through the top vent hole.
If you would like to call him directly let me know.
Old May 9, 2003 | 10:14 AM
Bandit1's Avatar
Bandit1
Default Re: Differential Leak??? (keith5)
:iagree: Same on my 99. Went through the whole gammit and four visits until they replaced the cover. According the TSB, the problem lies in poor machining of the cover by the sub. Good luck.
Old May 9, 2003 | 11:41 AM
mozart's Avatar
mozart
Just had to have my side cover and axles seals replaced on mine at less that 10K. Dealer did the work under warrantee and have had no re-occurring leaks as to date. The initial leak was a nuicience leak, about one to two drips a day over a two week period. They used dye and found the side cover leaking and also replaced the axles seals . This seems to be a common problem with the getrag.
Old May 9, 2003 | 05:31 PM
JCR's Avatar
JCR
Default Re: Differential Leak??? (Bandit1)
Bolt leaking?. It has to get passed the "O" Ring to get to the bolts though. I remember that when I replaced my old O Ring it looked ok. It must harden under heat and pressure and a seepage results that finds its way to a bolt hole and then shows itself. Forget the damn O ring and use a good anaerobic sealer or even a good high temp gasket making silicone . That is the sure fire fix in my opinion.
To Differential Leak???
