Another Oil question
Old May 27, 2003 | 11:29 AM
ozarkone's Avatar
ozarkone
Default Another Oil question
How much is the normal amount of oil you need to add between oil changes? It seems like I need to top it off to much. What Mobil 1 oil do most of you use 5w30 10w30 or the 15w50 raceing type? :rolleyes:
Old May 27, 2003 | 12:08 PM
Xssesive's Avatar
Xssesive
Default Re: Another Oil question (ozarkone)
I usually don't have to add any oil between changes(every 6 mos.). I use the 5W-30 year around, although I think the 10W-30 would also work fine.
Old May 27, 2003 | 12:46 PM
vettenuts's Avatar
vettenuts
Default Re: Another Oil question (Xssesive)
Not using Mobil-1, volatility and in range viscosity are my concerns. What year is your car?
Old May 27, 2003 | 02:00 PM
redsmarc's Avatar
redsmarc
4th Gear
I'm adding a quart every 2500 miles!!!! 2002 Coupe and it kills me....
Old May 27, 2003 | 02:42 PM
Mark S.'s Avatar
Mark S.
Default Re: Another Oil question (redsmarc)
I'm adding about a quart every 2000 miles. It sucks, but it's better than allowing my local Chevy Dealership to re-ring the engine. :nono:
Old May 27, 2003 | 02:54 PM
FormerBiker's Avatar
FormerBiker
My Y2K FRC goes 3-5000 mile between oil changes and I have never had to add any. I must be one of the lucky ones. :yesnod:
Old May 27, 2003 | 04:17 PM
Cirrus8's Avatar
Cirrus8
I use Mobil 1 10w40 and have not had to add any between changes of approx 4000 miles. :D :D
Old May 27, 2003 | 05:24 PM
carpe dm's Avatar
carpe dm
Welcome to the Forum! GM says that 1 quart in 1500 miles is acceptable. (to them) I don't have to add any, as a rule, unless I have been doing some prolonged high speed runs. Then I may add a pint. You should not have to add any between changes, as far as I am concerned. Stick with the 5W-30 weight that GM recommends, as it flows better and protects as well any any other grade. Start keeping records to show Mr. Goodwrench....... :cuss :rofl:
Old May 27, 2003 | 05:47 PM
djluckyboy's Avatar
djluckyboy
Default Re: Another Oil question (Mark S.)
Re-ring the engine?? My car also burns oil....i get low oil level...seems every 1000-1500 miles.....what happens if you dont' get the engine ringed??
Old May 27, 2003 | 07:06 PM
Oldvetter's Avatar
Oldvetter
1998 Coupe with 63,000 miles, use Mobil 1 5W-30, UPF44 Oil Filter, change oil at 3% left DIC (6600 miles), use NO OIL between changes, doesn't even move off full mark !
Old May 27, 2003 | 07:44 PM
ozarkone's Avatar
ozarkone
The car is a 2000 model with 9k on it. :steering:
Old May 28, 2003 | 06:19 AM
vettenuts's Avatar
vettenuts
Going to put on my flame suit since this comment is counter to most forum beliefs, however Mobil-1 barely makes it into the 30 weight range. It is very close to a 20 weight oil. The volutility is also higher then some other oils on the market.
Just a suggestion, try a switch to Amsoil and see if your consumption is reduced. I recently switched several cars to this oil from Mobil-1 and found an overall reduction in oil consumed, especially in my Suburban. The volutility is much lower then Mobil-1 and the viscosity is near the upper end of the 30 weight range. For the cost, it is worth the experiment to see if this helps.
I don't work for Amsoil, don't sell it or am in any way affiliated with it, I have just been finding through my own experience and research that you consumption may be reduced compared to Mobil-1.
OK, flame suit is on :steering:
Old May 28, 2003 | 08:37 AM
ozarkone's Avatar
ozarkone
Would using something other than Mobile 1 void warrany? Has anyone heard of GM stepping up to the plate and fixing this under it's warranty? :skep:
Old May 28, 2003 | 08:42 AM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Take your car back to your dealer and ask to get on their oil consumption monitoring program. If you're going through enough oil, they will re-ring under warranty.
Good luck!
BTW, before the H/C install, I would need a quart about every 3000 miles or so. Wasn't a big deal because I get the oil changed at around 3000 miles or so anyways.
Old May 28, 2003 | 10:23 AM
Bandit1's Avatar
Bandit1
Using AMSOIL 0W-30 and Delco UPF-44 filters and don't have to add any between 5k oil changes.
:yesnod:
Old May 28, 2003 | 11:41 AM
Paul @ Thunder's Avatar
Paul @ Thunder
Default Re: Another Oil question (Bandit1)
I use Redline 5w30 and change it every 3000 miles and never have to add any oil. I did have the dealer replace pistons and rings with the LS6 coated piston and ring package, but I had no consumption issues before or after.
Old May 28, 2003 | 12:06 PM
Bob Lineman's Avatar
Bob Lineman
I used to go thru about 1.5 qts. between changes until i hit about 30k.
Now I add NOTHING. Still topped off after 3k. Go figure.
99 coupe 6sp.
To Another Oil question
Old May 30, 2003 | 03:35 PM
redsmarc's Avatar
redsmarc
4th Gear
My feelings precisely
Old May 30, 2003 | 05:45 PM
KAH_BigRedCorvette's Avatar
KAH_BigRedCorvette
'00 FRC, no oil used between 3k changes (I check weekly). I use Mobil 1 5w/30 full synthetic as recommended.
Old May 30, 2003 | 10:48 PM
SHOWTIME!'s Avatar
SHOWTIME!
98k and I use 1/2 qt. every 3k.
