Disconnect Battery, security code for radio
Old May 30, 2003 | 11:39 AM
Torqued84's Avatar
Torqued84
Default Disconnect Battery, security code for radio
I just bought a used 2000 MN6 Coupe and have a quick question. If I disconnect the battery, will I have to enter a security code on the radio or anything else when I reconnect.
Old May 30, 2003 | 11:58 AM
Norris's Avatar
Norris
Default Re: Disconnect Battery, security code for radio (Torqued84)
If any of the previous owners have entered a security code/activitated the security, then yes. If no security codes have never been entered, not a problem..Hope this helps. If the codes have been set and the radio becomes locked, search the forum for the procedure to unlock it or shoot me an email. I have the procedure copied in my computer files...
Old May 30, 2003 | 12:24 PM
mozart's Avatar
mozart
Default Re: Disconnect Battery, security code for radio (Norris)
If the security code has been set you will have flashing red lite on the radio. Do a search and the procedures for changing or resetting the code have been posted several times.
Old May 30, 2003 | 12:35 PM
lost's Avatar
lost
Default Re: Disconnect Battery, security code for radio (mozart)
The procedure is outlined in tech tips on this forum. It does work...binderdundat!!
Old May 30, 2003 | 01:18 PM
Torqued84's Avatar
Torqued84
Thanks for the help! :cheers:
Old May 30, 2003 | 07:37 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Simply turn the radio OFF before removing the key and disconnecting the battery and it wont go into lock mode...If the radio is on the ON position when disconnecting the battery,it will lock :yesnod:
http://www.vetteshop.cc/
Old May 30, 2003 | 09:59 PM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Disconnect Battery, security code for radio (MANNY)
What a great theft deterrent system that would be!
That is not so, of course.
Whenever the radio looses its battery power, it goes into "LOC", if the the theft deterrent system was set to on.
And that is does whether the radio was switched on or not.
:yesnod: :yesnod:
Old May 31, 2003 | 01:16 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Dude,I do this stuff every day :rolleyes: Having replaced hundreds of dead and leaky Delco's over the years,I have never had to unlock a radio :nono: Like I said,the known trick is to turn the radio to the "OFF" position before the key is removed or it will lock....
[Modified by C-5 TECH, 1:19 AM 5/31/2003]
Old May 31, 2003 | 05:04 AM
WWK888's Avatar
WWK888
Default Re: Disconnect Battery, security code for radio (C-5 TECH)
Can someone settle this...I would love to know the answer. If what C-5 TECH is true, what POS theft deterrent system we have. Then again the Bose isnt worth stealing :D
To Disconnect Battery, security code for radio
