Noise comming from Blackwing
Old Jun 1, 2003 | 02:16 PM
The Yav's Avatar
The Yav
Default Noise comming from Blackwing
Has any one experienced this: When starting the car and its idieling I can hear a noise coming form the air cleaner area (Blackwing) sounds like someone is using a spray paint can. (And no it's not the AIR pump). Any helpfull coments would be welcome.
v/r
THE YAV :chevy
Old Jun 1, 2003 | 02:59 PM
SpinMonster's Avatar
SpinMonster
Default Re: Noise comming from Blackwing (The Yav)
if you recently cleaned it and sprayed too much on it might just be sucking air harder with the restricted flow. Dirty will have similar sound.....dont go by the meter for cleaning
hope this helps
Old Jun 1, 2003 | 03:15 PM
The Yav's Avatar
The Yav
Default Re: Noise comming from Blackwing (SpinMonster)
Spinmonster;
Your the goods!! That exactly what I did cleaned the engine compartment. Do I need to take the cleaner off or will it correct it self?
v/r
THE YAV :chevy
Old Jun 2, 2003 | 02:07 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Since you already have the problem, I would take it off and clean it again. Even if the sound goes away, you can't be sure that there's not some type of restriction remaining.
Old Jun 2, 2003 | 11:41 AM
ryan0's Avatar
ryan0
Default Re: Noise comming from Blackwing (FunDriver)
at what rpm should you look at the meter?
mines brand new but still seems to be not flowing so well.
Old Jun 3, 2003 | 01:04 AM
SpinMonster
:iagree: clean again and be easy on the coating
Old Jun 3, 2003 | 10:57 AM
low flyier's Avatar
low flyier
how or what is the best way to clean the blackwing?
do i have to completly remove it?
is any water involved or just spray? :confused:
To Noise comming from Blackwing
