Under hood temp high
Old Jun 6, 2003 | 01:41 PM
skidmarc's Avatar
skidmarc
Default Under hood temp high
I just installed TPIS LT and not sure if thats the diff but it sure seems a great deal hotter under the hood......almost hot enuff to melt my fuel rail covers.....lol Is it from the headers?
Can I do anything?
Things I am considering.....programming fan to come on at 200 instead of 225.....rapping pipes with insulation......heat extractor hood........
any comments/ideas?
Old Jun 6, 2003 | 03:34 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Re: Under hood temp high (skidmarc)
FYI the fans come on at 205 with the air conditioner turned on./// cold air screens... work.
Old Jun 19, 2003 | 01:26 AM
EHS's Avatar
EHS
skid:
The headers wil do it. I would cut some vents into the hood over the headers.
Disipates the heat and looks really good.
Old Jun 19, 2003 | 06:00 AM
User 81424's Avatar
User 81424
Remove the rear hood seal, the one close to your wipers. This was brought up as a way to keep the hood from shaking at high autobahn speeds because it lets the under hood air escape. I did it and it works, and it did seem to lower under hood temps. The rain gutter still works, so unless you aim a hose at the gap your engine stays just as clean.
Old Jun 19, 2003 | 08:35 AM
MiamiDave's Avatar
MiamiDave
Default Re: Under hood temp high (CPT Z06)
Make sure you get "Cool Sox" which are high temp plug wire sheaths to prevent them from melting (wire condoms :p: ).
Also, get a 160-172 thermo (depending on if you have a winter) and have the fans kick in at 205 degrees.
Old Jun 19, 2003 | 09:21 AM
6Speeder's Avatar
6Speeder
Default Re: Under hood temp high (MiamiDave)
All sorts of good ideas here, one more for you: Remove the "flap" or seal between the engine cmpartment and the driver's side gill or cove opening. Don't do the passenger side, cause it keeps rain, etc. off the computer. You get to the seal from the wheel well. You'll be amazed how much air moves through the gill without the seal. :cool:
Old Jun 19, 2003 | 02:06 PM
wwashing's Avatar
wwashing
Take them off and have them Jet-hot (or some other) coated! :cheers:
Old Jun 19, 2003 | 03:36 PM
skidmarc's Avatar
skidmarc
Default Re: Under hood temp high (wwashing)
the headers are coated already.......hmm I have been toying with an idea of having those side ducts functional......I will have to look at the hood seal by the wipers and see whats entailed...Thanks for the idea.....are you talking about the tray the wipers sit in?
[Modified by skidmarc, 8:36 PM 6/19/2003]
Old Jun 20, 2003 | 03:53 AM
User 81424's Avatar
User 81424
Yes that tray, the seal is just pushed on, no glue or clips, it's too easy. Before I did this after a lap of the nurburgring I'd pop my to cool things off and feel the brake reservoir, it was always hot to the touch; after this there was a huge difference if felt temps. The other vette guys after checking there brake fluid started to pull of the seal too.
Old Jun 20, 2003 | 11:29 AM
skidmarc's Avatar
skidmarc
THANKS BUD...SO YOU PULL OFF THE WHOLE TRAY?
To Under hood temp high
