how to make steering more stable?
Have you had it aligned yet? Untill you have your search for a solution is useless.
Try these specs:
http://www.vettebrakes.com/align.htm
If you find yourself holding onto the steering wheel (at speed) with more pressure than you use to squeese a tube of toothpaste, you are using too much pressure!
Anyway, the answer was to increase the caster slightly, and make sure that the cross caster (difference from one side to the other) is small. According to the alignment technician, who I respect (he did the alignment on a Ferrari I had), most alignments have more caster on the right to offset the slope of most roads to the right. This gives the casual driver the impression of the car going straight when the road slopes to the right.
At the beginning of the alignment, my front end had 6.3 degrees caster on the left and 6.8 degrees of caster on the right. Now I have 7.1 degrees on the left and 7.3 degrees on the right. Even though these numbers are at the high end of the spec, the car is easier to steer. (BTW, toe is about neutral.)
So for more stability, you can either increase the toe in, or decrease the caster.
:cheers:
Maybe you could try a front spoiler or lower the car a little more in the front. If you have lowered the car and lowered the rear more than the front, the lack of rake that was designed into the chassis is comprimised. Kind of sounds like you have an aerodynamic issue. This is assuming your alignment isn't screwed up, tires are in good shape and properly inflated, suspension/steering isn't damaged or worn out. I have never heard anyone complain about the steering on a C5 and the steering is one thing that many of the car mags raved about when the C5 first came out. Hope you figure it out... :cheers:
[Modified by daveydc5, 1:58 PM 6/17/2003]
