GP: Valaya Racing Debris Guards
**EDIT** I was able to flatten out the piece sufficiently. I didn't think it would be that pliable when I first looked at it. All is good!!!
[Modified by C5 StockSwap, 10:07 AM 9/12/2003]
Any creative folks out there??
I'm assuming here that the debris guard prevents the hook from clamping on to the front fascia due to the tight clearance.
Loosely attach a few zip-ties through the holes in the debris guard about 1" behind the front edge wherever the bra would normally attach. Then slip the bra hooks through the zip-ties and pull them tight. If you're worried about it breaking, use mechanics wire instead, but a quality zip-tie that's at least 8" long (when straight) should hold just fine.
:cheers:
Actually, it attches with snaps under the front fascia. The snaps replace the stock hardware precisely where the Debris Guard attaches. The issue is that the bra snaps are not long enough to handle the extra thickness caused by the Debris Guard. Longer snaps, or some sewn on hook mechanism would work. Zip ties won't cut it, but that's just for me!
1. Found snap only (no screw) in the specialty hardware drawers at OSH store.
2. Found automotive trim screws, 1", same place. They have the same threading as the stock GM screws used for the front facia.
3. Used a bench grinder on the tops of the screws to lower the tops a tiny bit.
4. Put screw through snap, screw through debris guard and facia into screw receptacles (I think they're called zeus clips).
By the way, I suggest bending the tabs in the front on the debris guard before mounting so they fit better. In addition, it is not necessary to remove the two inner screw for the center air dam piece, just the outer screws and it will slide out.
The guard is very pliable, so don't worry when it arrives bent up (mine did too).
[Modified by allanlaw, 3:00 PM 9/12/2003]
Thanks for the great info...Love the forum!
Elliott Miyashiro
Valaya Racing
408-448-8811
