If you have dropped your Vette and have a spare sec can you measure the distance from the ground to the bottom of your fender lip for me? Please make sure you are directly in the center or highest point of your wheelwell.
My buddy lowered his Z06 exactly the same way I did and he still sits taller even with the same size tires. I assume it is his Z06 suspension but it now has me curious how low some of you guys are. Also how you lowered the front.
Here are my measurements:
Front: 26 1/8th (stock rims/tires)
Rear: 26.5" (This is with 275/40/17 tires on though)
Front 25 3/4" Cut 2/3 bushing off the front.
Rear 26 3/4" 7" bolts on rear, but cannot remember how many threads showing, quite a few as I raised it up about an 1" in the rear. Stock Z06 tires and rim sizes. :cheers:
