Better Performance
Old Jun 21, 2003 | 11:14 AM
Richard9933's Avatar
Richard9933
Default Better Performance
Hello All,
I just purchased my 2000 Yellow Convertible (Automatic) with only 6700 miles on it. It looks like a brand new car. Two years ago I had a Z06, but always wanted a convertible.
Help please, what can be done performance wise to really increase hp like that of a Z06? I live in West Palm Beach, Fl.
Any shops in my area that cater to my type of request.
Any and all advice would be great.
Thank You,
Richard :seeya
Old Jun 21, 2003 | 11:50 AM
Killrwheels's Avatar
Killrwheels
Default Re: Better Performance (Richard9933)
Norris Motorsports in Orlando or Breathless Performance in Dania Bch. Both have some great options. You also might like Driver's Seat in Boca (off Glades) for your detailing needs ! :thumbs:
Old Jun 21, 2003 | 12:45 PM
Richard9933
Default Re: Better Performance (Killrwheels)
Thank you very much....
Richard
Old Jun 21, 2003 | 01:11 PM
Richin Chicago's Avatar
Richin Chicago
Hello All,
Thank You,
Richard :seeya
Unless the car already has the optional hi performance (option G90 on the inside glovebox door) 3.15 REAR AXLE RATIO – I would start there. The standard GU2 2.73 is pretty slow off of the line.
As an aside if you still have the original GM battery (catalog #1809?) I would suggest replacing it immediately. Quite a few of these leak and if they do they leak right a wiring harness and the computer!
Beware of large claims for Cat back muffelers and breathers.
Old Jun 21, 2003 | 03:43 PM
Cary's Avatar
Cary
Default Re: Better Performance (Richin Chicago)
:iagree: the 2.73 is a starting point to modify. May I suggest a 3.42 rear, if you presently have a 2.73 rear. I went with that switch & mpg did not change very much & at 75mph my tach reads 2200 rpms :thumbs:
I had my state inspection renewal done at a Chevrolet dealership and they did a visual check all around & under my battery for possible leaks. None were found :)
I really like my Borla Stinger system & have dyno sheets to prove a rwhp gain was achieved from same. The sound is purrfect :yesnod:
My Vortex Rammer intake system is a pain to check the filter but would still get the same system again.
May I suggest you look at other C5 sigs on the CorvetteForum for mod ideas.
Good luck :cool:
[Modified by Cary, 2:44 PM 6/21/2003]
To Better Performance
