LG Production Headers!
Old Jun 22, 2003 | 09:39 PM
Z06 scotty's Avatar
Z06 scotty
Default Re: LG Production Headers! (Godspeed)
what are the length of each tube are they equal.???? :steering: :steering: :steering:
Old Jun 22, 2003 | 09:52 PM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: LG Production Headers! (C5 StockSwap)
Hi Guys,
I ll butt in here for a minute. The lowest part of the original LG Longtubes was the "V" flange clamps. The new production set does not use the V flanges any longer. It was one way to reduce the cost. This in fact allows for better ground clearance. But keep in mind that the original hand made headers already had plenty of clearance.
YES, we will still build the custom sets of LG Longtubes just as before. I have 10 sets of tubes on the way from Stainless Works as we speak. They will still use V flange connections and also use the expensive hand made racing merge collectors. Nothing with regard to our original headers will change. And for those of you who want only the best, then we will be at your service and continue to provide the "Original".
The new "LG Longtube headers by Borla" (as they will be labled) will be of the same design as the originals but they will be a production version. ie 32" primaries, merge collectors, and 3" x pipe. The Merge collectors will now be machine made. That was a big help in reducing the cost. Plus the production capacity of Borla to build 50 sets at a time, in less than one week, is a hugh factor in reducing the price. The function and performance of thes headers and production merge collectors, is only slightly less than the racing Merge collectors, but still superior to most other collector choices. The dyno results above still show the BIG low end torque where you can feel it.
The production system comes in 3 sections. first the headers with welded merge collectors. Then the 3" X pipe with clamps at the front and rear of the X. And then the last 3" section that connects the X pipe to the muffler at the 2, two bolt flanges. It is all 3 inch tube and only reduces to stock where it connects to the mufflers.
The cats will install inplace of the X pipe. This will allow the cats to be interchangable with the X pipe with normal flat clamps. We had to eliminate the V flange clamps to reduce the cost. What you will get at first is the "Off road" version. which will not include cats. We are working with Random cats to come up with a package that can be an easy accessory to the system, and provide for easily installed cats. But I reitterate that the first systems will be off road versions without cats, until we can get with Random.
At any rate, what you see in the photo is the full LG Longtube system by Borla, in 304 stainless steel. And stainless steel headers hold the heat in, so coating is not necessary for heat reduction. Coating would only be used for looks.
for those of you who already have an X pipe, you can sell those on the forum, and reduce your cash outlay.
Feel free to call me with any questions or to place your order.
Lou G
Old Jun 22, 2003 | 10:06 PM
hrdtopv8's Avatar
hrdtopv8
SCHWEET!! Gotta start saving now.. :thumbs: How long do you guys plan on keeping the price at $1495?
[Modified by hrdtopv8, 9:07 PM 6/22/2003]
Old Jun 22, 2003 | 10:07 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: LG Production Headers! (LG Motorsports)
Lou,
How does that X pipe with the new kit compare to the "TANDEM CROSSOVER" X pipe you guys used on your orginal system?
Phillip
Old Jun 22, 2003 | 10:35 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: LG Production Headers! (hrdtopv8)
This pricing is good only for preorders. Once the headers arrive pricing will be 1595.
Old Jun 22, 2003 | 10:39 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: LG Production Headers! (Phil97SVT)
Great clarification Lou...although Jeremy did a great job as well. I just passed my Texas inspection, so i'm good for a year and the "off-road" version will be fine for a while. However, I'm not clear on the new cats replacing the x-pipe. Will that mean no X-pipe at all with cats in place, and therefore the Corsa Indy's will be back to popping like crazy on deceleration?
Thanks, and I'm ready to buy when I get back from the 50th. Will you be up there with a set to show off?
Thanks,
Steve
Old Jun 22, 2003 | 10:41 PM
C5 StockSwap
Cruise-In V Veteran
oh...one more thing...how much for an install?
Old Jun 22, 2003 | 11:05 PM
alexWS6's Avatar
alexWS6
:withstupid:
Old Jun 22, 2003 | 11:14 PM
LG Motorsports
Default Re: LG Production Headers! (alexWS6)
Install................................. ..........................$250.00
LG :yesnod:
Old Jun 22, 2003 | 11:30 PM
C5 StockSwap
Cruise-In V Veteran
LG :yesnod:
Thanks for the quick response Lou! If I bring lunch can I get a better deal? :cheers:
Old Jun 23, 2003 | 12:14 AM
aurik's Avatar
aurik
Elite Member
Default Re: LG Production Headers! (Dugmole)
:cool: :cool: :cool: :cool:
Schweeet! My cash flow is rather strapped, but I suspect I may be getting a set of these installed for Cruise-In V
[Modified by aurik, 12:20 AM 6/23/2003]
Old Jun 23, 2003 | 12:41 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Re: LG Production Headers! (aurik)
After these headers release, I think all other headers will go bankrup :D
Old Jun 23, 2003 | 01:07 AM
  #33
kumar75150's Avatar
kumar75150
Default Re: LG Production Headers! (mike76002)
Lou, let me know if it would be possible to get just the headers. I have a 3" x-pipe from Stainless Works already.
Old Jun 23, 2003 | 01:49 AM
  #34
Cary's Avatar
Cary
Hey Lou,
I'll call you around 10 am in the morning to place my Pre Production LT order.
I've been waiting, and bugging you & Jeremy, since March about these LT's. It will be so :cool: to have my 01 C5 Coupe at 350RWHP, about the same as a 2003 Z06 (stock). Right now I have 321.8RWHP and Jeremy (Godspeed) thinks with the Production LT's & re-tune he can get me to or real close to 350RWHP :D
Old Jun 23, 2003 | 07:11 AM
  #35
C5_SWISS's Avatar
C5_SWISS
Old Jun 23, 2003 | 07:52 AM
  #36
geekracer's Avatar
geekracer
Those do look nice. :cool: Since they're made by Borla, you might consider an option to replace the back section with a Borla XR-1 type resonator without reducing the diameter. Perhaps include the over the axle section as well. Make a full exhaust system out of it. :cheers:
Old Jun 23, 2003 | 08:53 AM
  #37
LG Motorsports
Default Re: LG Production Headers! (MMarquez)
Right now, Borla is considering a 3" Stinger to go with this. I am sure that if there is demand, then it will get built.
thanks guys.
LG
To LG Production Headers!
Old Jun 23, 2003 | 08:59 AM
  #38
Quick Brick's Avatar
Quick Brick
So the way it sets LG will sell this as an off-road system? It would need sims or to be edited for rear O2's. I bet that setup could make a Corsa Touring cat back roar! :lol: :rofl:
[Modified by Quick Brick, 8:00 AM 6/23/2003]
[Modified by Quick Brick, 8:37 AM 6/23/2003]
Old Jun 23, 2003 | 09:34 AM
  #39
LG Motorsports
Default Re: LG Production Headers! (Quick Brick)
All systems will come from LGMotorsports. This is a Private label system that is being built for LG Motorsports by Borla, under our name.
At first this will be an off road system. We will send the Xpipe to Random as soon as we can, to get the catalytic converters built. this will be an option that will be a little down the road.
Thanks,
Lou G
Old Jun 23, 2003 | 09:46 AM
  #40
Cary's Avatar
Cary
thanks guys.
LG
Lou, LGM installed the Borla Stinger on my C5 back in March. So, there will be no problem with connecting the Pro LT System to my Borla Stinger, right?
Please IM me.
:cheers: Cary
