A-4 Looking For Ideas
Old Jun 25, 2003 | 08:41 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Default A-4 Looking For Ideas
Need help on a super clean transmission cooler install. Need your thoughts,pics would be great. :yesnod: Thanks for you thoughts. Ron B.
Old Jun 25, 2003 | 10:13 PM
TLewis4095's Avatar
TLewis4095
Default Re: A-4 Looking For Ideas (itsonlyairandfuel)
Although I don't have pics to post...I mounted 2 coolers, one on each side of the Vortex Rammer and cut the shroud to allow the air to be forced through the coolers. It looks neat & custom, dosen't obstruct the radiator, and stays a minimum of 20 degrees cooler than the coolant temp. :cheers:
Old Jun 26, 2003 | 01:42 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
click on image for a larger view
Old Jun 26, 2003 | 12:59 PM
itsonlyairandfuel
Thanks for the posts. Now I have a place to start, any others would be appreciated. Ron B.
Old Jun 26, 2003 | 01:50 PM
RWhite's Avatar
RWhite
Don't have any good pics, but mounted mine (bought all the parts including cooler from Manny, Moe, and Jack :D ) on the passenger side of the shroud next to the Blackwing. Cut a square hole under cooler. Easy mod and a must if you are in a hot climate. Looks like you do not have to worry about that.
Old Jun 26, 2003 | 02:32 PM
TLewis4095's Avatar
TLewis4095
Default Re: A-4 Looking For Ideas (RWhite)
Sounds very similar to my set-up, except I did 2...one on each side. :cheers:
Old Jun 26, 2003 | 04:53 PM
SFVetteman's Avatar
SFVetteman
Default Re: A-4 Looking For Ideas (REDGAR)
I'm going with a B&M transcooler but I will be using braided hose and threaded fittings instead of clamps. Does anybody know what the fitting size is on the transmission line?
Old Jun 26, 2003 | 10:31 PM
gary brown's Avatar
gary brown
From: Los Angeles Founder, West Coast Corvette Challenge
Default Re: A-4 Looking For Ideas (SFVetteman)
Bill - you might want to consider getting the B&M racing tranny cooler (better than the 24000). I tried both and the racing cooler is a big improvement. Hope this helps.
Gary
Old Jun 27, 2003 | 02:21 PM
SFVetteman's Avatar
SFVetteman
Default Re: A-4 Looking For Ideas (gary brown)
Perhaps I should have asked around a bit more before I ordered the 24000 :banghead: However, I did order a 3qt finned aluminum pan so maybe the combination will be enough.
Old Jun 27, 2003 | 06:23 PM
mfrnka's Avatar
mfrnka
Where can I find the oversized finned A4 tranny pan?
Old Jun 27, 2003 | 08:24 PM
gary brown's Avatar
gary brown
Default Re: A-4 Looking For Ideas (mfrnka)
B&M
Old Jun 27, 2003 | 08:56 PM
itsonlyairandfuel
Gary which cooler did you Use The 29,000 gvw ?
Old Jun 28, 2003 | 12:30 AM
mfrnka's Avatar
mfrnka
B&M
Is this the standard 4L60E pan from B&M, part# 70260? If so, the drain/fill hole is on the bottom of the pan and may cause an issue when trying to refill the tranny. Does B&M have a new pan with a side plug available? I have seen several custom pans, but they tend to be a bit pricey.
Old Jun 28, 2003 | 09:12 PM
gary brown's Avatar
gary brown
I don't know the part number. The pan must have a hold drilled in the side for the filler plug. Contact Eric at Rebs Specialties in Reseda, CA. They can give you all the details. http://www.rebsspecialties.com
Hope this helps.
Gary
To A-4 Looking For Ideas
