Electronic Climate Control acting "funky"...
Old Jul 10, 2003 | 11:49 AM
bradfordjr's Avatar
bradfordjr
Default Electronic Climate Control acting "funky"...
Yesterday, the temps here in Northern Virginia were in the high 90's, but when I cranked-up my vette, the outside temp display read 44 degrees :banghead: After I drove about 5 miles, the temp display started going up like a slot-machine until it reached the correct temp of 99 degrees. I had no HVAC codes, so I'm thinking that it's either my inner or my outer temp sensor gone bad :yesnod: Any thoughts? :rolleyes:
Old Jul 10, 2003 | 11:55 AM
gonbad's Avatar
gonbad
Default Re: Electronic Climate Control acting "funky"... (bradfordjr)
Its the outer sensor located on the passenger side just in front of the radiator shroud with a little tube sticking out. Replace both the sensor and the connector. The sensor is like $9 and the connector is like $25. Then use water proof heat shrink to seal the splice and the connector to the sensor.
This happens due to water corroding the connection between the sensor and the connection.
Old Jul 11, 2003 | 05:34 AM
bradfordjr's Avatar
bradfordjr
Default Re: Electronic Climate Control acting "funky"... (gonbad)
Thanks for the reply...I'll check it out this weekend. :yesnod:
To Electronic Climate Control acting "funky"...
