Headlight Vibration issue...
Old Jul 12, 2003 | 02:52 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Headlight Vibration issue...
I've got the APC Xenon 9005 and 9006 bulbs.
When i'm driving, and drive over a bump, I notice the low beam light wiggle. I popped the cover off, and checked to see if it was loose. but the bulb was inserted tightly.
Has anyone had this problem? I've had them in there a year, so I dont remember if my stock bulb had the same issue.
Old Jul 12, 2003 | 03:34 PM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Headlight Vibration issue... (y2k02c5)
check the stops for the whole assy, not just the bulb.
Old Jul 13, 2003 | 04:06 PM
YLWFVR75's Avatar
YLWFVR75
I failed to mention that this problem is only the passenger side.
Old Jul 14, 2003 | 04:24 PM
Corvette00Car's Avatar
Corvette00Car
Catch it quick. On my car the cap on the pin wasn't installed and the pin slid out. I am waiting until Carlisle so I can measure for a new pin. It looks about 3/8 in diameter. My pin is somewhere on the highway. In the alternative the nylon bearing could have worn out.
To Headlight Vibration issue...
