Blackwing install problems?
Old Jul 24, 2003 | 09:00 PM
vmaxcraz's Avatar
vmaxcraz
Default Blackwing install problems?
I heard from a couple of guys that there is a problem with the blackwing mounting holes not lining up. Has anyone here had a problem installing this. :confused: or is this just a bunch of :bs
Old Jul 24, 2003 | 09:07 PM
Bob Chapman's Avatar
Bob Chapman
Default Re: Blackwing install problems? (vmaxcraz)
The Blackwing install on my 02 was a 45 min job. The airbridge mounting holes do not line up for full reinsertion but it's not a problem.
Old Jul 24, 2003 | 09:52 PM
paid4c4's Avatar
paid4c4
Default Re: Blackwing install problems? (Bob Chapman)
I just installed mine and while I did go back and adjust it to fit, I'm still not happy with the install. It fits over the posts but does not lay flat, it rubs against the insulation for the hood. I'm going to try it one more time, perhaps some use has loosened things up a bit.
Bill :) :)
Old Jul 24, 2003 | 10:08 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Blackwing install problems? (paid4c4)
Tip: Leave all clamps loose enough (even at the MAF) so you can readjust the position on everything prior to tightening. This has helped me. :)
Robert
[Modified by LoneStarFRC, 9:08 PM 7/24/2003]
Old Jul 24, 2003 | 11:13 PM
AKFINEST's Avatar
AKFINEST
Default Re: Blackwing install problems? (LoneStarFRC)
:iagree:
Old Jul 25, 2003 | 02:27 AM
lowdowndirty's Avatar
lowdowndirty
Default Re: Blackwing install problems? (AKFINEST)
Mine is off a little, but I installed a carbon fiber air bridge at the same time. :iagree:
Old Jul 25, 2003 | 03:10 AM
MagRed2002's Avatar
MagRed2002
Default Re: Blackwing install problems? (lowdowndirty)
I have seen at least one C5 here in Chicago that experienced problems with the intake system "bowing up" when installing the Blackwing. Seemed like the complete assembley was just a little "too long", if you know what I mean.
I already had a Halltech CF airbridge when I installed the BW - still I had the dimentional issue. It still seemed as if the system was a bit too long. With mine, I carefully trimmed the silicone coupler (up by the throttle body) to half it's original lenghth and it fit like a glove. If you have retained the original accordian coupler and bridge, it may not fit quite right, as I referenced above. Generally, however, everybody seems to love the Blackwing.
I'll be interested to see if anyone else has seen any fitment problems with the BW.
Old Jul 25, 2003 | 05:47 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Blackwing install problems? (MagRed2002)
I had that issue until I loosened clamps and pushed them on a little better. Fits perfect now.
Old Jul 25, 2003 | 07:51 PM
LoneStarFRC
Default Re: Blackwing install problems? (BQuicksilver)
:iagree: Yup, that's what I was talking about in my previous post. The factory rubber boots, especially those nearest the MAF, have deeper grooves than most people realize. Here's where some soapy water really helps to get you're pieces shoved all the way into the grooves of the boots.
Old Jul 26, 2003 | 12:24 AM
jedicowboy's Avatar
jedicowboy
Mine fit like a glove....After I re-installed it about 3 times. :lol:
Old Jul 26, 2003 | 09:22 AM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: Blackwing install problems? (jedicowboy)
Same here...Trick for me was to put some silicone grease over each of the grommet areas (4), loosen everything and then pop in place. Went flush with the radiator shroud, then tightened all the fittings. If fits great but just takes some work.
Old Jul 26, 2003 | 10:57 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
No problem what so ever. Everything fit like it was suppose to. Took about 45 minutes, but I'm old and slow. :yesnod:
Old Jul 26, 2003 | 12:56 PM
rhoeven's Avatar
rhoeven
I had to file out the left front hole of the Donaldson a little less than 1/10th of an inch (make it slightly elliptic) to make it 100% fit.
Then the airbridge can be installed totally flush with the shroud. I used Vaseline at all airpath rubber parts.
Hope this helps.
Roger
:cheers:
Old Jul 26, 2003 | 02:49 PM
vmaxcraz's Avatar
vmaxcraz
Thanks to all who replied. It looks like I will just have to take a little care and time to make sure all clamps are left loose untill parts are fully together. Again Thanks, Dave :seeya :grouphug:
To Blackwing install problems?
