vararam letting dust past through
Old Aug 4, 2003 | 02:16 AM
66ImpalaLT1's Avatar
66ImpalaLT1
Default vararam letting dust past through
I decided to check my filter tonight on the vararam, pulled it out and it looked fine. It could probably use a cleaning but nothing urgent. In the process my maf came out of the top part so I took them both off the car to reconnect them.
The upper part of the vararam had dust on the inside in back (toward the engine). It was all the way up to the MAF. The filter showed no signs of dirt passing through or around it so I'm not sure how its getting in there.
I'm thinking about either a K&N or paper filter for the street and keep this foam one for the track.
Any thoughts?
Eric
Old Aug 4, 2003 | 06:21 AM
vettenuts's Avatar
vettenuts
Default Re: vararam letting dust past through (66ImpalaLT1)
I have long been suspicious of the Vararam filtering capability, especially after some of the comments about a "noticable decline in performance" when the K&N is put in instead. I really believe that someone should do an oil analysis with one of these things in place to see how much is getting through the filter. This is the main reason I have stuck with my Donalson, and the oil analysis on the Donaldson has come back terrific so it is indeed doing it's job of filtering.
Old Aug 4, 2003 | 12:03 PM
corvette184's Avatar
corvette184
Default Re: vararam letting dust past through (vettenuts)
:lurk:
Old Aug 4, 2003 | 12:18 PM
Mike Siska's Avatar
Mike Siska
Default Re: vararam letting dust past through (corvette184)
I've had my Vr1b in for 4,000 miles and haven't had any problems.
Old Aug 4, 2003 | 01:34 PM
66ImpalaLT1
Default Re: vararam letting dust past through (Mike Siska)
Mike, I have had my Vararam about twice that long, and I live in dust filled Arizona.
Eric
Old Aug 4, 2003 | 04:09 PM
Mike Siska's Avatar
Mike Siska
I noticed when I changed my filter (Patrick made one and overnighted it to me at no cost-just unbelievable service he provides), that the back of the part that fits over the filter doesn't fit all the way down over the filter. We have had more rain than dust here on the east coast, so maybe that's why I didn't see any dust. But I usually have to take the airbridge off to be able to pull the top off so I can get to the filter to clean it. Does yours fit all the way down in the back over the filter?
Old Aug 4, 2003 | 05:45 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Could someone post of good pic of the highflow vararam filter?
thanks
Old Aug 4, 2003 | 06:40 PM
Dope's Avatar
Dope
Resident moron
What did you expect? That foam vararam filter is basically 'race only'. Were you running it for daily driving?
Dope
Old Aug 4, 2003 | 08:13 PM
Face's Avatar
Face
Default Re: vararam letting dust past through (Dope)
Dope
This is why I ordered a K&N at the same time. Foam for race day, K&N for the streets. :cheers:
Old Aug 4, 2003 | 09:02 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: vararam letting dust past through (Face)
Not the first time I've heard this....a friend of mine sold his after about one month of use....lot's O dirt getting by.
Old Aug 4, 2003 | 10:55 PM
66ImpalaLT1
Default Re: vararam letting dust past through (Z06 Quin)
I took it out tonight to clean it and found the problem. The edges are falling apart and I can see how air would pass around the foam. The glue isnt holding at all. I ordered a K&N.
Eric
Old Aug 4, 2003 | 11:21 PM
AllCammedUp's Avatar
AllCammedUp
Good move, Eric. I ordered one of the K&N's from Patrick almost immediately after seeing the foam filter. I've had the K&N in from day one, and have been very satisfied with it. Peace of mind is worth the 5 HP or so.
I don't see how the foam filter keeps out anything smaller than a marble, figuratively speaking. ;) Lay the foam down on a newspaper, and you can dang near read the print. :crazy:
Old Aug 4, 2003 | 11:36 PM
66ImpalaLT1
Default Re: vararam letting dust past through (AllCammedUp)
Does the K&N fit well?
Eric
Old Aug 4, 2003 | 11:43 PM
AllCammedUp
It's a bit bigger than the foam filter, and it is a nice and snug fit, and I like that. :)
Old Aug 5, 2003 | 08:23 AM
TooManyIDs's Avatar
TooManyIDs
...I ordered one of the K&N's from Patrick almost immediately after seeing the foam filter. I've had the K&N in from day one, and have been very satisfied with it. Peace of mind is worth the 5 HP or so.
:iagree:
With the foam filter, I suspect oiling is critical.
[Modified by TooManyIDs, 7:25 AM 8/5/2003]
Old Aug 5, 2003 | 08:25 AM
TooManyIDs's Avatar
TooManyIDs
Eric
Yes, it does.
Old Aug 5, 2003 | 10:01 AM
chukzukisilver99's Avatar
chukzukisilver99
Default Re: vararam letting dust past through (TooManyIDs)
What's the part number on the K&N filter? Is it the normal C-5 filter or special order?
To vararam letting dust past through
Old Aug 5, 2003 | 10:34 AM
tlaselva's Avatar
tlaselva
Default Re: vararam letting dust past through (chukzukisilver99)
K&N for Vararam: Part# 33-2522
The race filter should be used for just that. Racing.
K&N for the street, where 5HP not going to make a diff.
Old Aug 5, 2003 | 10:53 AM
chukzukisilver99
Default Re: vararam letting dust past through (tlaselva)
Thanks for the numbers. The minor Hp loss will be well worth the longevity of the engine.
Old Aug 5, 2003 | 10:59 AM
chuckster's Avatar
chuckster
Silly question...but..
Did you oil the filter good before you installed it?
I used the K&N spray oil on mine. I sprayed the air inlet side of the filter only. I covered it real good. Then I pressed an old rag on it to blot up the excess. I can see dirt having a better chance of getting through that than my K&N's..
The oil is what makes the dirt and dust stick....It has to be there.
