Plugs and Wires
Old Aug 14, 2003 | 09:34 PM
nightboom's Avatar
nightboom
Default Plugs and Wires
Any reccomendations on plugs and wires? Are the 4 point platinum better than the iridiums?
MSD wires?
Thanks!
Old Aug 14, 2003 | 09:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Plugs and Wires (nightboom)
I changed the plugs in my 98 (@ 60,000 miles) and used the origional rapid fires. They work fine for a non moded engine. I checked all of my wires with an OHM meter prior to reinstalling them and 6 of them read 320-360 ohms. The other two read 2-3 MEG OHMs :cuss :mad . I did alot of investigation prior to a wire purchase and chose the Magnecore wires. Reading their wire write ups may have solved one of my engine problems. For the past year I have been getting weird one time codes on the DIC. I can clear then and most of them nevre repeat. I moved the two bad wires away from the ECM and the codes have just about stopped happening. BAD wires cause BAD things to happen on a LS1/LS6!!
I have decided to purchase the MAGNECORE Compention 8mm wires. They retain the origional heat shields and many forum members like and recommended them. They were $60.84 + $4. shipping. (They came on Wednesday :hurray: ) I ordered them from the magnecore website. It was cheaper that way. The local ricer shop wanted $90.00 for them.
I have to get them in SOON so I can take the car to Carlisle PA!!
Bill Curlee
Old Aug 14, 2003 | 10:25 PM
Xssesive's Avatar
Xssesive
Default Re: Plugs and Wires (Bill Curlee)
I replaced mine with Magnecore's! But MSD and Taylor both have good wires you can use. I think the Bosch +4's are not a very good plugs, I use the NGK TR 55's with good results. But I have heard on the forum LAPD pushes the Iridiums, so I am sure they are also a fine plug. :yesnod:
Old Aug 14, 2003 | 11:37 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Plugs and Wires (Xssesive)
I use the Taylor thunderbolts 10mm and NGK Tr 55's with my setup. :thumbs: :iagree:
Old Aug 15, 2003 | 12:01 AM
Driven2WIN's Avatar
Driven2WIN
Have you found that changing wires has improved performance?
added horsepower?
Old Aug 15, 2003 | 12:16 AM
ScreaminDemon's Avatar
ScreaminDemon
I had the Magnecors but they wouldn't fit my setup, I needed a longer wire. Bought the MSD universal 8.5's and cut them to fit. Plugs are NGK TR55's, a copper, hotter plug than irridium or platinum, and best for nitrous. The downside is they will wear out sooner, but I replace mine every oil change, they are very cheap, $1.69 at NAPA.
Old Aug 15, 2003 | 07:26 PM
Xssesive's Avatar
Xssesive
Default Re: Plugs and Wires (cporantes)
If you still have the stock wires and plugs, they will definetly help! The stock plugs lose there pucks and the stock wires were causing some misfires on an Autotap read. Don't believe GM's claim about the longevity of these items.
Old Aug 15, 2003 | 09:48 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
They wont add any performance but will allow you to get everything that your origional horsepower raring gave you. If the origional ones were marginal you were loosing power. New ones will give you back what you lost.
Bill C
Old Aug 18, 2003 | 12:00 AM
AZGASSER's Avatar
AZGASSER
any tips on changing the plug esp plug 7 and 8? TIA for your help! :seeya
Old Aug 18, 2003 | 12:06 AM
tboo's Avatar
tboo
Default Re: Plugs and Wires (AZGASSER)
#8 is easy. #7 isnt that bad getting it out, but man what a pain in the A@@ getting the wire on the plug. I just changed mine with NGK tr55s & Accel 300+ wires. The damn plug wire heatshields made it a bitch getting the accels on the plug. I finally gave up & just put the wires on without the shields.
Old Aug 18, 2003 | 12:13 AM
RoadVette's Avatar
RoadVette
AZGASSER,
Just changed mine. Go to Tools-Tech Tips-C5. There is a write up there that is pretty good. The article suggests getting a SNAP-ON Double Swivel 5/8 6-point Spark Plug Socket. This will definately make it easier, but not necessary. You just need to loosen the plug and then remove it by hand. Make sure you leave the spark plug socket on the plug. It makes it easier for your fingers to turn. Also, if you have some miles on your car, I have 50,000, do a decarb. This is also under tech-tips. Very easy to do and I could not believe the wake up call my car has received from the decarb and change in sparkplugs (NKG T55 IX). Good Luck!!
Old Aug 18, 2003 | 01:08 AM
tboo's Avatar
tboo
Default Re: Plugs and Wires (RoadVette)
hey roadvette, at what mileage should you do a decarb(I have 36000)? Can I do it if I just changed my plugs & wires?
Old Aug 18, 2003 | 10:09 AM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Default Re: Plugs and Wires (tboo)
We have these wires with kevlar heat shields as pictured, and we have the basic wires in Red or Blue for $69. using real GM connectors.
The non heat shielded G2 super wires are new to our product line so I will pick up the shipping for the wires.
thanks
Lou G
Old Aug 18, 2003 | 05:15 PM
1 BAD C5's Avatar
1 BAD C5
Default Re: Plugs and Wires (LG Motorsports)
I just installed the NGK Iridium plugs and the G2 wires. The wires are a great build quality and well worth the money in my opinion.
To Plugs and Wires
