Battery keeps dieing
Old Aug 16, 2003 | 01:13 PM
402Sam's Avatar
402Sam
Default Battery keeps dieing
My battery on my car keeps dieing. It died a while back and I figured out that I had a bad alternator. Got it fixed and it ran great. Last night I hooked up a maf translator to the car and drove it all night w/o any probs. Go to start tha car this morning and dead. Jumped it, got it runnin, checked to see if I left any inside lights on and nothing. Now the battery gauge reads 12volts. Any idea what could be killing the battery. Tha maf translator????
Old Aug 16, 2003 | 03:34 PM
quimbo's Avatar
quimbo
Default Re: Battery keeps dieing (sprayedc5)
I would say when you first killed the battery you did it in and now that the Hot Weather is here!!!!! its cooked get a new battery
QUIMBO :seeya :seeya SEEYAAAH
[Modified by quimbo, 3:35 PM 8/16/2003]
Old Aug 16, 2003 | 04:44 PM
SFVetteman's Avatar
SFVetteman
Is that with the engine on or off?
Old Aug 17, 2003 | 11:22 AM
carpe dm's Avatar
carpe dm
What type of battery do you have? If it is an AC Delco, I would opt for a new one (they do have a much improved model) or an Optima as a replacement. Once they are "dead", they often fail to revive completely and do not hold a good charge. I would go for new, and a Battery Tender! :smash: :yesnod: :)
Old Aug 17, 2003 | 07:24 PM
Quikturn's Avatar
Quikturn
Dying, not dieing you silly boy! :smash:
Old Aug 17, 2003 | 07:37 PM
Dave68's Avatar
Dave68
A jump and a drive is not enough to fully recharge the battery. Any number of auto parts stores can run a load test on the battery to tell whether it is shot or not. Never assume the battery is at fault unless
a) It is approx. 5 years old or older
b) It cannot be charged completely
If you DO need a replacement battery, don't get a standard lead-acid type - if it ever leaks, your computer and wiring mounted below the battery could be toast. Get an AGM-type battery. ACDelco makes a 650 CCA Platinum, as does Optima with its Red Top.
Good luck!
Old Aug 17, 2003 | 07:43 PM
John Wiz's Avatar
John Wiz
Default Re: Battery keeps dieing (Dave68)
If it is the Delco AGM it is probably dead (mine died at 3 years and 4 days) wouldn't last the weekend even after a deep cycle charge. Go and get a Red Top Optima do not go with another Delco AGM POS...
Old Aug 18, 2003 | 09:50 AM
wwashing's Avatar
wwashing
Judging by your wagon wheels you have a'97 or '98. If this is the original battery, it's at least 5 years old. After having been completely discarged during it's life, I'd say it's time for a new battery! :cheers:
Old Aug 18, 2003 | 10:11 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Re: Battery keeps dieing (wwashing)
Mine did the same thing even with the new battery I put in when I got rid of the delco---replaced the altenator as it was not getting a charge, it killed a cell in my new battery which was under warranty---removed the battery box and found the delco had leaked and though it took a while to do it, it had corroded a lot or wiring under the battery box, my extended warranty fixed the problem thank god as the starter (450 bucks) also needed replacement, I would deff pull the battery box and look at your wiring, remember you may not see it on the insulation as it slips inside the insulation and attacke the wiring, run a meter on the main red wire that goes to your positive side of the battery and runs to your starter etc. and if you have the delco dump it--this is a 10 dollar battery on a 50K car---
Old Aug 19, 2003 | 02:03 PM
vettedevil's Avatar
vettedevil
Time for a red top! :thumbs:
Old Aug 20, 2003 | 10:11 AM
Fast one's Avatar
Fast one
Default Re: Battery keeps dieing (C5Coup)
Check the current draw when the car is off, should be around 20ma after 1 minute.
To Battery keeps dieing
