headers are killing my starter
Old Aug 27, 2003 | 07:28 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default headers are killing my starter
My car was slow starting so I brought it to the dealer. Turns out the heat from the header melted the plastic shroud and heat soaked the starter, rendering it useless. I am going to put some header wrap on to control the heat.
Old Aug 27, 2003 | 07:52 PM
DocSandy's Avatar
DocSandy
From: When I say who is the mastah you gotsta say Shonuf
Default Re: headers are killing my starter (ICULUKN-C5)
What headers do you have?
Who did the install?
How long have you had them on?
[Modified by DocSandy, 6:55 PM 8/27/2003]
Old Aug 27, 2003 | 08:14 PM
Z06 Mike's Avatar
Z06 Mike
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: headers are killing my starter (DocSandy)
Exactly the reason I went with the Swaintech coating on my StainlessWorks headers. You might want to look into it. Talk to MattG.
Good luck!
Old Aug 27, 2003 | 08:47 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: headers are killing my starter (OCMike)
They are TPIS headers installed by Xtreme Motorsports.
Old Aug 27, 2003 | 08:53 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
Hmmmmm, need to check. I haven;t looked but I havent had any problems either.
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
wow, I have run my TPIS for over 2 years now without any problems.. :eek:
VR :cheers:
Old Aug 27, 2003 | 11:23 PM
SpinMonster's Avatar
SpinMonster
Default Re: headers are killing my starter (vetterdstr)
Did you get the jethot coated ones?....if not get them coated.
Old Aug 27, 2003 | 11:28 PM
Dave68's Avatar
Dave68
My 68 had the same problem, but the literature that ca,me with the Doug Thorley headers specifically warned against wrapping them. Apparently, the internal heat increases to a point where the steel can develope cracks. Always check with the manufacturer before wrapping or coating headers.
To headers are killing my starter
