Oil level check ?
Old Aug 30, 2003 | 04:18 PM
6 speed Sid's Avatar
6 speed Sid
Default Oil level check ?
How do you see the fresh Mibile-1 oil on the stick? The stuff is so clear, I can't see it on mine. Changed the oil, jacked up the rear, put in a little over 6 1/2 qts. Wuth the rear jacked, a lot more oil came out. Does it take more than 6 1/2 with the rear jacked?? Thanks.
Old Aug 30, 2003 | 04:20 PM
vettenuts's Avatar
vettenuts
Default Re: Oil level check ? (6 speed Sid)
I always found that I needed 7 to get it to the full line cold (letting it sit overnight, prior to start).
Old Aug 30, 2003 | 04:23 PM
Jim 47's Avatar
Jim 47
What????? :confused: NO. The capacity of the crankcase is 6.5 qts regardless of the configuration of the body of the car. :sad:
Old Aug 30, 2003 | 04:27 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Just because you get a little more oil out by raising the back doesn't mean you can put more oil in. lower the car to the ground and make sure it's level, then just fill to the full line.
Old Aug 30, 2003 | 04:45 PM
carpe dm's Avatar
carpe dm
6 1/2 qts. should do it! I have to take my dip stick outside in the sun to see the level, when the oil is fresh. Tip: always check your oil in a consistant manner; i.e., cold, or warm, after it sits 5 minutes following shut-down, after standing over night, etc. The new sticks have a hole at the "full" point. If yours does not, take a piece of sand paper and scuff the metal up to the proper place. This will make it easier to see. :)
Old Aug 30, 2003 | 10:39 PM
Fang S-289's Avatar
Fang S-289
Default Re: Oil level check ? (carpe dm)
Or drill a small hole in the dipstick as I did. It works great!
Old Aug 31, 2003 | 12:01 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Re: Oil level check ? (Fang S-289)
Sounds like bi-focal time. The little holes should fill with oil. Have a great weekend.
Old Aug 31, 2003 | 12:40 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
try using a flash light.. :yesnod:
VR :cheers:
Old Aug 31, 2003 | 08:22 PM
Start about the full line and wipe a clean finger across the dip stick until you see where the oil comes to.
Old Sep 1, 2003 | 05:52 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
if you are checking when the oil is hot make sure the dip stick is cold by putting it in cold water first. the oil will stick better i check my oil after leaving the car set over night with the dip stick out on the bench,that way the oil you dragged up the tube will have run back down and not give you a false reading:chevy :chevy
To Oil level check ?
