C5 Automatic Transmission Flush/Replace Procedure ??????
Old Sep 1, 2003 | 11:40 AM
plcoppell's Avatar
plcoppell
Default C5 Automatic Transmission Flush/Replace Procedure ??????
I have consulted with my local Chevrolet dealer about changing the transmission fluid in my 2001 automatic. I am told that they have tried using a B&G machine to perform this operation on a C5 but after 10,000 miles they had to replace both transmissions.
I went to Jiffy Lube (not my first choice I assure you) and they claim that they can do it by hooking up a machine to the two lines going into the radiator, running a cleaner through the system first and then the transmission fluid.
I sure would like to know what Chevrolet's procedure is on this and if dealers can perform the operation successfully without any fears of future transmission damage.
I am not a mechanic and wouldn't risk trying to change transmission fluid on my own. I live in the Dallas area and would be interested in anyone with experience with a local mechanic or dealership.
Surely Chevrolet Motor Division is not counting on anyone not getting to the 100,000 mile mark and needing a flush. I run my in autocross/drag events plus Driver's edge. Having added a torque converter (PT 2600), I am concerned about old fluid causing damage.
Help Please ........
Old Sep 1, 2003 | 12:39 PM
H82BFST's Avatar
H82BFST
Default Re: C5 Automatic Transmission Flush/Replace Procedure ?????? (plcoppell)
How about instead of a power flush, why not just do it the old fashion way? Drop the pan, change the filter, refill. 84K later and tons of abuse and still going...
Old Sep 1, 2003 | 06:05 PM
plcoppell's Avatar
plcoppell
I have dropped the pan in the past but the most that you can get out is 4 quarts, leaving 6.8 quarts of bad stuff. I supoose you could keep doing that for 3 or 4 tiems and you would have most of it out. Not what I am looking for but thanks....
Old Sep 1, 2003 | 06:15 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
We have the BG flush equipment and have performend hundreds of flushes without a failure :skep:
To C5 Automatic Transmission Flush/Replace Procedure ??????
