cooling problem
Old Sep 19, 2003 | 09:38 PM
ROMARNV's Avatar
ROMARNV
Default cooling problem
01 vert-- temp got to 220 range, i turned on ac, she cooled down -- i'm sick of the service dept, any ideas out there-- this dependable car, is becoming a pain in the A!!!!!!!!!!!!!!!!!!
thanks guys
romarnv :banghead:
Old Sep 19, 2003 | 09:50 PM
C5Doug's Avatar
C5Doug
Default Re: cooling problem (ROMARNV)
I put a 175 stat on mine with a coolant bypass. I also lowered the temp
that my cooling fans come on to 180. Now it rarely goes over 190. :yesnod:
Old Sep 19, 2003 | 10:31 PM
SSTRUCKNGUY's Avatar
SSTRUCKNGUY
Default Re: cooling problem (C5Doug)
:iagree: thats the best answer youll get....
Old Sep 19, 2003 | 11:47 PM
Bill Dearborn's Avatar
Bill Dearborn
Nothing wrong with those temps. Forget about it. The people in the service dept will think you are crazy.
Bill
Old Sep 20, 2003 | 12:29 AM
ROMARNV's Avatar
ROMARNV
Default Re: cooling problem (Bill Dearborn)
thanks guys, thought it might have been a code-- so i cleared them--drove & then let her idle - temp was 196 driving--up to 228 sitting @ idle--then started to cool down
:rolleyes: :cheers:
Old Sep 20, 2003 | 09:19 AM
duosy's Avatar
duosy
Believe me - that is normal for Vette. With over 300K on mine, I can tell you that years of running in that heat range didn't do anything to destroy the engine. :steering:
Old Sep 20, 2003 | 09:23 AM
C6~Missle's Avatar
C6~Missle
Default Re: cooling problem (duosy)
Over 300K miles on your C5?? Please tell us more.. what problems have you had...if any.. thanks and congrats!
mike
Old Sep 20, 2003 | 11:53 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Bill
:iagree:
If you notice where the red line is for cooling , you will see your in the right range... Nothing wrong with those temps...
Old Sep 20, 2003 | 12:17 PM
BLUTHUNDER's Avatar
BLUTHUNDER
Default Re: cooling problem (Evil-Twin)
You might want to check the wiring on your fans to assure that there both working..I had a similar problem and it turned out to be a broken fan wire.
Only one fan was working , once we diagonsed the problem my temps went from 220 down to 190 .
Good Luck !
:cheers:
Jeff
Old Sep 20, 2003 | 07:37 PM
C6~Missle's Avatar
C6~Missle
Default Re: cooling problem (BLUTHUNDER)
Wouldnt a broken fan or fan wire cause an error code? Cant believe the programming/sensors wouldnt catch it
mike :confused:
To cooling problem
