Drilled stock rotors?
Old Sep 20, 2003 | 10:48 AM
jmzvet's Avatar
jmzvet
Default Drilled stock rotors?
I know that drilled rotors are for looks only but is there any reason why a competent machine shop couldn't drill your stock rotors for an appearance mod? Are most aftermarket rotors drilled or are the holes somehow cast into the metal? Replacement rotors are pretty cheap, under $100 a set (4) at some places, and if a machine shop could drill them for $100 you could save a few hundred bucks :cheers: .
[Modified by jmzvet, 8:00 AM 9/20/2003]
Old Sep 20, 2003 | 10:52 AM
Z11409's Avatar
Z11409
Default Re: Drilled stock rotors? (jmzvet)
GM factory drilled rotors cost $138 a piece-only for looks no help in performance
Old Sep 20, 2003 | 10:54 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I am sure it is possible although I would not waste any money on doing it. If you want the real good looking zinc washed, slotted and drilled rotors... get the baers and run stock pads. They will stay looking the best with stock pads. :smash:
VR :cheers:
Old Sep 20, 2003 | 01:38 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Drilled stock rotors? (vetterdstr)
Forum member WGreen drilled his own rotors at home. He is no machinist. I have seen them, they look good. The only thing it cost him was time, lots of time!
:D :cheers:
Old Sep 20, 2003 | 04:37 PM
jmzvet's Avatar
jmzvet
Default Re: Drilled stock rotors? (racer44)
I suppose if you had a good drill press & some sharp bits, there is no reason it couldn't be done at home.
Old Sep 20, 2003 | 04:43 PM
94-98 Trans Am's Avatar
94-98 Trans Am
You say its only for appereance? I'm sure they wouldn't warp nearly as fast as stock rotors. I could be wrong..someone correct me if I am.
Old Sep 20, 2003 | 07:01 PM
NJblack99coupe's Avatar
NJblack99coupe
Default Re: Drilled stock rotors? (94-98 Trans Am)
Might not warp but under hard conditions i hear they could crack easier.... someone said to me "crossdrilled rotors are great for racecars, but then after the races we throw the rotors away so it doesn't matter."
Old Sep 20, 2003 | 07:02 PM
Dave68's Avatar
Dave68
A drill bit will inherently leave fairly sharp corners, whereas a cored hole features generous radii - much better when trying to avoid stress-cracking. From what I've heard, slotted and cored rotors run cooler than stock rotors and may very well prevent the dreaded rotor warp we all experience at one time or another.
Old Sep 20, 2003 | 09:56 PM
Richin Chicago's Avatar
Richin Chicago
I don't think stock rotors warp:
http://www.stoptech.com/whitepapers/...otors_myth.htm
As I have mentioned before I have seen too many warped rotors "cured" by hard repeated braking on the track. It wipes off pad material build up.
Old Sep 20, 2003 | 10:05 PM
DngrZne's Avatar
DngrZne
Default Re: Drilled stock rotors? (Richin Chicago)
From my understanding the way to go is slotted. I seem to remember someone saying that Ferrari uses slotted rotors on their race cars and drilled on their street cars. When a Ferrari representative was asked why he said that the slotted actually serves a purpose while the drilled is merely for appearance. Not sure how accurate this is tho...maybe someone else knows better than I do...
Chris
To Drilled stock rotors?
