using non-runflats...help...
Old Sep 24, 2003 | 08:39 AM
te51cle's Avatar
te51cle
Default Re: using non-runflats...help... (spoiled996)
I run 32-33 psi cold in both the EMTs and the Falkens. I usually end up adding about 2 psi to whatever the manufacturer recommends (in our case 30 psi) which suits UK roads and my driving style.
My tyre over-pressure alarm goes off at 42 psi so if you leave the tyres at 42 psi you'll probably get an alarm go off a couple of miles down the road !
Old Sep 24, 2003 | 01:04 PM
allanlaw's Avatar
allanlaw
Default Re: using non-runflats...help... (XTrooper)
Who cares if you ruin a tire sensor? You can replace them for around $50 now and I'd rather spend an extra $50 and be on my way in minutes . . .
I don't disagree, and would suggest carrying both the fix-it kit and a can of goop. If the circumstances are not ideal for tire repair, then shoot in the goop and spend the cash on another sensor down the road. My flats have usually been spotted when I can do the fix without problems (I've just been lucky). It would be good to have the option :cheers:
Old Sep 24, 2003 | 01:44 PM
XTrooper's Avatar
XTrooper
Default Re: using non-runflats...help... (allanlaw)
Not a bad idea. :thumbs: However, "lucky" would be to not get a flat tire at all! :yesnod:
Old Sep 24, 2003 | 01:53 PM
allanlaw's Avatar
allanlaw
10-4 :thumbs:
Old Sep 24, 2003 | 04:12 PM
duosy's Avatar
duosy
Default Re: using non-runflats...help... (Tsab)
Using the run flat version of these tires. Love them - so much better than the Goodyear run flats. Only have 33K on the set so far. I expect they will go the 50K that the Goodyears did. :steering:
Old Sep 24, 2003 | 11:42 PM
C6 Snowboarder's Avatar
C6 Snowboarder
Default Re: using non-runflats...help... (OldSStroker)
Oldstrokers -- Are you saying you went thru 3 sets of Potenzas in 65,000 miles? That has to suck or you were having toooooooo much fun with the pedal to the floor. :cheers:
[Modified by C5 Snowboarder, 8:44 PM 9/24/2003]
Old Sep 25, 2003 | 01:53 PM
mrtoner's Avatar
mrtoner
I just called around to get a set of Kunhos of Fuldas for my '97, and everyone says Kuhmo does not have one in the right size for the rear.
What is everyone else doing?
Old Sep 25, 2003 | 01:58 PM
98VETTEC5's Avatar
98VETTEC5
Default Re: using non-runflats...help... (mrtoner)
they have the right size, they just have to take the time to find it. I'am a tire dealer and my supplier had a hard time finding them!
Old Sep 25, 2003 | 05:42 PM
OldSStroker's Avatar
OldSStroker
Default Re: using non-runflats...help... (C5 Snowboarder)
Snowboarder:
I went thru 3 sets of F1 EMTs in 65K. This is the first set of S03s.
I like to DTSOOI, or as Ol' Dad Baskerville may have said, "Drive The Snot Out Of It !".
on second thought he probably didn't say Snot. RIP, GB.
Hey, how do we quote a post on this board? Newbie queston.
[Modified by OldSStroker, 10:43 PM 9/25/2003]
Old Sep 25, 2003 | 06:00 PM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
im getting some non-runflats put on today. The Kuhmo MX ecsta...Goodyear is installing them, but says that using non-runflats will make my car ride like s**t. is this true? Seems like most people on here love getting of the run-flats. :confused:
You better check to see if your lug nuts are tightened. I wouldn't trust anyone who makes that claim -- pure :bs They'll ride much better.
Old Sep 25, 2003 | 07:37 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
32 PSI pilot sports non run flats...
45 is WAAAAAAAY too high!
