HID experts, need help
Old Sep 26, 2003 | 12:38 AM
boost2much's Avatar
boost2much
Default HID experts, need help
One of my HIDs stopped working. At first I thought it was the ballast but had that replaced. Still wouldn't work. Checked the relay and it was working fine. THe bulb will flicker but won't stay on. Everyonce in awhile it will come on but then turn off after a min. Is the bulb bad? If it is, does anyone know a place I can get just one HID bulb? :confused:
Old Sep 26, 2003 | 12:50 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: HID experts, need help (boost2much)
Try your other bulb on the bad side.. if the bulb works then... buy a new bulb... You can get one through LAPD...
VR :cheers:
Old Sep 26, 2003 | 01:37 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: HID experts, need help (vetterdstr)
Sorry I can't help on this one, but I'm curious as to how this will all pan out. Keep us posted!
Old Sep 26, 2003 | 10:37 AM
boost2much's Avatar
boost2much
That's a good idea. I will switch the bulbs and see if its the bulb. I sure hope not. I'm bummed cause I bought a new ballast and it wasn't the problem :rolleyes:
To HID experts, need help
