rev limiter question
Old Sep 29, 2003 | 06:20 PM
SAXN8R's Avatar
SAXN8R
Default rev limiter question
Okay,
I did a search and wanted to confirm my findings.
Is the stock rev limiter set at 6200 in coupes and verts and 6600 in the Z?
Old Sep 29, 2003 | 10:52 PM
Am I Badd's Avatar
Am I Badd
Default Re: rev limiter question (SAXN8R)
From what I can tell , stock, mine was set at 6200. 2000 coupe.
[Modified by Am I Badd, 9:56 PM 9/29/2003]
[Modified by Am I Badd, 10:03 PM 9/29/2003]
Old Sep 29, 2003 | 10:58 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: rev limiter question (Am I Badd)
All I know is I'm glad it's there! :yesnod:
Old Sep 29, 2003 | 11:04 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
I think your findings are correct. :iagree: :cheers:
Old Sep 30, 2003 | 08:54 AM
te51cle's Avatar
te51cle
6200 on the LS1 Corvette it is.
Old Sep 30, 2003 | 09:12 AM
Patches's Avatar
Patches
:yesnod: And redlines are at 6000 for the LS1 and 6500 for the LS6.
Old Oct 1, 2003 | 05:51 PM
FKING1's Avatar
FKING1
Default Re: rev limiter question (Patches)
Official Corvette Specs are 6000 for LS1 & 6500 for ZO6.
Fred K.
Old Oct 1, 2003 | 05:59 PM
Thunder7's Avatar
Thunder7
Default Re: rev limiter question (FKING1)
Has anyone had it kick in before? I did one time by accident.....recently.
:leaving: Oops....
Old Oct 1, 2003 | 06:06 PM
QUIKAG's Avatar
QUIKAG
Default Re: rev limiter question (Thunder7)
:leaving: Oops....
hahaha, I've hit it dozens of times. I wouldn't do it every day, but it's not anything to stress about at all if you hit it occasionally.
Old Oct 1, 2003 | 07:33 PM
SAXN8R's Avatar
SAXN8R
:leaving: Oops....
I hit it all the time....
not to bragg, okay well maybe a little bragging....I hit it in 5th gear last Sunday. :D :seeya
Old Oct 1, 2003 | 09:16 PM
lager99's Avatar
lager99
St. Jude Donor '06
:leaving: Oops....
:bb :bb :thumbs:
Old Oct 1, 2003 | 09:22 PM
GR8-LIFE's Avatar
GR8-LIFE
I have a 99 vert and I can say for sure that mine has kicked in right at about 6200. Defintely not 6K as I hit this many times during track events without interuption. This is just what I have noticed on my car.
Old Oct 1, 2003 | 10:20 PM
NIGHTMARE...2001's Avatar
NIGHTMARE...2001
Mine's set at 6700 rpm. :thumbs:
Of course the object is to not hit the rev limiter which protects your engine parts, because if you do, it's going to shut down your engine's ability to accelerate momentarily!:( Hitting it even for just a moment will cost you in a race or at the track! :rolleyes:
Before my current mods, I bought a HPP3, and changed the rev limiter to 6400, which is supposed to be about the limit, on taking chances with the stock LS1 engine. So I've been told anyway. :) With one of these simple programmers, you can change your shift points so this doesn't happen, on an A4. Obviously you're going to want to shift prior to the rev limiter setting. :D
Old Oct 2, 2003 | 12:58 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: rev limiter question (NIGHTMARE...2001)
Factory setting on the LS1 Rev Limiter is at 6250.
Bill
Old Oct 2, 2003 | 01:25 AM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: rev limiter question (Bill Dearborn)
if you bang off the limiter in a drag race in both shifts{a-4} how much does it effectt your timeslip???i hit it in both shift's tonight... :mad
Old Oct 2, 2003 | 08:47 AM
NIGHTMARE...2001
Default Re: rev limiter question (MC TORCH RED)
Since you are dealing with an activity that is being timed in fractions of a second, the impact will be signifcant. The time it takes you and your motor to recover from such an event, is lost time which cannot be made up.
In the case of a six speed, he must watch his rpms closely or use a shift light I would think, but in your case MC, since you drive an A4, your shift points need to be altered, so that you are shifting one or two hundred rpm before the rev limiter setting, and reset the rev limiter to that recommended for your cam/springs set up.
I had my stuff set by 21MC, but a person who doesn't want to use a tuner could still set their own shift points with a hand held programmer.
[Modified by NIGHTMARE...2001, 7:54 AM 10/2/2003]
Old Oct 2, 2003 | 09:29 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
If you're hitting it in an A4 you're
A) slipping or
B) programmed incorrectly or
C) shifting yourself or
D) all of the above :)
If it's bad enough you'll hang on the limiter and not be able to complete the shift which will whack your times of course. I know of at least one guy that decided it was faster to go through the traps on the limiter in 3rd rather than shift to 4th, but that was a six speed and you know how those guys are. :jester
Did this start all of a sudden or gradually get worse?
To rev limiter question
Old Oct 2, 2003 | 11:52 AM
Patches's Avatar
Patches
Default Re: rev limiter question (MARK's_C5TT)
Mark, for the record, redline and rev limiter are two different values GM cites for the LSx's. Redline is a value the engineers set as a "voluntary" throttle back-off point for the driver and is designated on the tach as the beginning of the red section of the gauge demarcations. The rev limiter is designed to cut fuel to the engine because the redline has been exceeded and engine damage and/or failure is imminent. The rev limiter is a physical fail-safe built into the control system which actively prevents catastrophic engine failure regardless of the driver's actions. Rev limit for the LS1 is set at 6200 - 200 rpm beyond redline. For the LS6, it's 6600 or 100 rpm beyond redline.
So when you say your's kicked in at 6200, this is what one would expect since you drove through the indicated redline engine speed on your tach.
:cheers:
[Modified by Patches, 11:53 AM 10/2/2003]
Old Oct 2, 2003 | 12:01 PM
TopCat's Avatar
TopCat
:iagree:
And if you raise your rev limit, you chance floating the valves. According to Lingerfelter, float them once and the valve springs are shot and need to be replaced. Just my 2 cents. :jester
I had this problem manually shifting my A4 since I had to try to time it just right without hitting the rev limiter, especially from 1st to 2nd. Not a problem anymore. TRANSGO!!!! :D
Old Oct 2, 2003 | 12:42 PM
MC TORCH RED
Default Re: rev limiter question (TopCat)
ok i have a new cam and it was shifting to early at 6200, i raised it to 6400 , but didn't raised to limiter. they are just to close. :yesnod:
