Porting/Polishing throttle body..
Old Oct 8, 2003 | 07:37 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
Default Porting/Polishing throttle body..
Any noticable benefits to doing this :confused: Thanks for replies :cheers:
Old Oct 8, 2003 | 07:39 PM
dave777's Avatar
dave777
St. Jude Contributor
Default Re: Porting/Polishing throttle body.. (Scratch)
I noticed a little better throttle response, I did it myself
Old Oct 8, 2003 | 07:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Mine's coming off soon! Lots of people say that the HP increase is small BUT the driveability and throttle responce is a LOT better! :thumbs:
I figure it this way IT CANT HURT!!!
BC
Old Oct 8, 2003 | 07:56 PM
Scratch's Avatar
Scratch
Default Re: Porting/Polishing throttle body.. (dave777)
I did mine also...main goal was to polish the exterior..but since I was there :D Havn't driven it yet..just wondering if any benefit.
Old Oct 8, 2003 | 08:58 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Was it difficult to polish the outside? How did it come out? I hand polished the entire upper intake on my Mustang and that was a beeeeoooottch. Took about 30 hours.
Old Oct 8, 2003 | 09:56 PM
Scratch's Avatar
Scratch
Default Re: Porting/Polishing throttle body.. (Cajundude)
Looks like chrome :D
I had done this by hand, buffer, ect. Same with the altenator, bracket and some other stuff..including the entire rear suspension. I have a knack for this :D I like it. However, this time, I took it apart..and wasn't happy with the results, so went to a pal's that has a wheel polishing shop..looks great!!
Old Oct 8, 2003 | 10:10 PM
msuc5vette's Avatar
msuc5vette
Sounds sweet, I have often thought about doing my suspension as well, I just can't get that motivated!
Please post pics :thumbs:
Old Oct 9, 2003 | 11:48 AM
Cajundude's Avatar
Cajundude
Sounds good. I may have to give it a shot. Can't possibly take as much time as that intake I did.
Old Oct 9, 2003 | 12:58 PM
Scratch's Avatar
Scratch
The prep is the hard part..the right tools/ equip. make the difference..but it makes the final buff that much easier. The suspension parts in the rear, same deal..if you have alot of access to a lift..then really easy to get to and do..
mine is lowered also, wife thinks I'm nuts..but when your behind, it's visble.
Had it at Extreme Motorsports getting new rubber mounted..was standing outside, and then I heard alot of.."dayammms and check this out"! :D
Old Oct 9, 2003 | 02:11 PM
Cajundude's Avatar
Cajundude
Gotta love that. That's what it is all about. It makes you feel good when someone shows appreciation for your car. This post has made me decide that I am going to all least try and do a lot of cosmetics myself, at least at first unless I really screw something up then I'll have to buy the really cool replacement. I think it would make me feel even better if I had the appreciation and I did the work myself.
What did you use to get into crevices and hard to get spots (ie, corners)?
Old Oct 9, 2003 | 11:16 PM
Scratch's Avatar
Scratch
Die-grinder air tool..on a small shaft, rubberized bullets and also pointed sanding rolls..all in different grits..used also with tripoli rouge! Corners come out good/great..but generally not "perfect"! :D
To Porting/Polishing throttle body..
