acceleration problems
Old Oct 17, 2003 | 07:11 PM
Stanman's Avatar
Stanman
Cruising
Default acceleration problems
I just bought my first Vette, 50th AE. I'ts great! Although now that I'm getting use to it, it seams as if there is a delay when I punch the throttle from about 30%. What could cause this delay?
Also, thanks for developing this forum. I've been checking it out well before I bought my vette. Cheers :cheers: [IMG][/IMG]
Old Oct 17, 2003 | 10:10 PM
rhoeven's Avatar
rhoeven
Default Re: acceleration problems (Stanman)
Welcome to the forum.
Do you have an automatic or 6-speed?
Roger
Old Oct 18, 2003 | 12:43 PM
Stanman's Avatar
Stanman
Cruising
Default Re: acceleration problems (rhoeven)
I have a six speed. I notice the lag mainly in first gear when I start to accelerate from about 30% throttle to wide open. The lag is about 2 seconds before re-engaging.
Old Oct 18, 2003 | 03:23 PM
rhoeven's Avatar
rhoeven
Maybe due to wheelspin, the active handling kicks in. Try with AH off.
Hope this helps
:cheers:
Old Oct 18, 2003 | 03:25 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
:iagree:
Sometimes the tires are spinning & you can't hear anything! Happens to me sometimes, so I'm used to it & can tell if/when it's happening! Hope that's all it is!
Old Oct 18, 2003 | 03:37 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Welcome to the board and I hope the problem is minor.
:thumbs: :seeya
Old Oct 18, 2003 | 07:21 PM
WWK888's Avatar
WWK888
Are you sure about the "2 seconds"? Thats seems like a real long time...
I agree with the others, its probably silent wheel spin.
Old Oct 19, 2003 | 12:24 AM
Welcome and congrats on the new Vette. Hopefully it is just wheelspin.
Old Oct 20, 2003 | 12:18 AM
Stanman's Avatar
Stanman
Cruising
Default Re: acceleration problems (WWK888)
Well, when your without power it seams longer than it probably is. You may be right it could be wheel spin. Now that I think of it, this doesn't happen in any other gear. thanks for your help>
Old Oct 20, 2003 | 01:00 AM
LS1NUT's Avatar
LS1NUT
the problem is this your cam doesnt make power until about 3500 the ls1 motor is great but it doesnt start to build peek torque until the high rpms. dont worry there is a ton of after market parts to fix that and anybody who says it weel spin is dead wrong a stock c5 in my opinion is a dead slug thats why you have to start with bolt on modifications if you want to fix your accelerating problem put 3.90s or 4.10s in spend 1800 because thats what it cost to do everything including the computer but you will have twice the car you have now. be care full alot of after market parts are a scam a donot do much but three things I know that work excellent a good set of long tube headers xpipe and exhaust, gears, and air intake the most important is gears its like riddind a 10 speed bike if you start off in the tenth speed setting its harder to get going compared if you start in first
Old Oct 20, 2003 | 01:04 AM
LS1NUT's Avatar
LS1NUT
one more thing if you put the peddle to the floor and cant tell if the wheels are spinning you shouldnt be driving a corvette get something that has front wheel drive because thats pretty scarry
Old Oct 20, 2003 | 09:21 AM
denali's Avatar
denali
St. Jude Contributor
Have you tried a after market air filter yet? You may be pleasently suprised. The stock unit is very restrictive.
Old Oct 20, 2003 | 04:02 PM
Carsnob's Avatar
Carsnob
Default Re: acceleration problems (LS1NUT)
This is not exactly true. No it doesn't make a lot of horsepower 'till higher up in the rpm's but good torque is available down low. In fact good torque is available almost EVERYWHERE.
Here's a breakdown of my dyno sheet per every 100rpm (just had intake and exhaust when this was done. Over 300lb' at 2800 all the way to 5700rpm = FUN!)
Old Oct 21, 2003 | 12:22 AM
LS1NUT's Avatar
LS1NUT
2800 or 3500 is relitivily in the same range ok so I m a few rpms off big deal and remember the tach on the dyno is not in calabration with the factory one so on the dyno its 2800 in the car its 3300-3500 ok close enough call it day
Old Oct 21, 2003 | 12:23 AM
LS1NUT's Avatar
LS1NUT
read my post i said about 3500
Old Oct 22, 2003 | 04:57 PM
Stanman's Avatar
Stanman
Cruising
Default Re: acceleration problems (denali)
I haven't tried an aftermarket air filter yet . . .I'm a little confused of which to buy. I've been reading this forum for quite a while and there seams to be a lot of talk about the Varam and the Blackwing.
Old Oct 22, 2003 | 07:20 PM
Monster231's Avatar
Monster231
go with blackwing
To acceleration problems
