changing plugs
Old Oct 20, 2003 | 10:47 AM
skidmarc's Avatar
skidmarc
Default changing plugs
any tips/tricks/tools make it easier to swap plugs in the hard to reach areas?
Thanks in advance guys!
Old Oct 20, 2003 | 11:03 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Re: changing plugs (skidmarc)
I would buy a SNAP-ON Double Swivel 5/8 6-point Spark Plug Socket.
Part Number is: S9721 I haven't changed the plugs in my car yet but I heard this makes the job A LOT easier.
Old Oct 20, 2003 | 11:46 AM
BSiegPaint's Avatar
BSiegPaint
I've found that just using a smaller 3/8" drive wrench and 5/8 socket with an 8" extension seems to get right back to the rear driver's side without a hitch. If it's too tight, add a swivel. Use a shorter extension for the other driver's side plugs, if needed. Passenger side, you won't have any problems. Pull off the vacuum hose from the brake booster and hold it out of the way and you'll have plenty of room to work.
Old Oct 20, 2003 | 02:10 PM
skidmarc's Avatar
skidmarc
Default Re: changing plugs (BSiegPaint)
thanks for the tips to make it easier guys!
Old Oct 20, 2003 | 02:19 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
That snap on double swivel is 42 dollars...and you will probably only use it once in your life time.... a 3/8 drive 5/8th spark plug socket and a swivel and extension did the trick for me...took about 15 minutes to get # 7 in and out... and 15 minutes to do the other 7 plugs... there is a metal clip right over the area where you need to get your hand in # 7 so as to get a hand start for that plug... if you remove that clip, things will be alot easier...and you wont lose as much blood..... :smash: :blueangel:
Be prepared to put on new wires... you may find a bad wire after removing them....
[Modified by Evil-Twin, 2:23 PM 10/20/2003]
Old Oct 20, 2003 | 02:20 PM
vette.se's Avatar
vette.se
Remove the coilpacks - it's only five bolts and you will have all room you need without having to get special tools.
:cheers:
Old Oct 20, 2003 | 05:01 PM
gmblack3's Avatar
gmblack3
Default Re: changing plugs (vette.se)
:cheers:
:iagree:
Old Oct 20, 2003 | 05:12 PM
Evil-Twin's Avatar
Evil-Twin
Default Re: changing plugs (gmblack3)
:cheers: :iagree:
The coil packs are on top of the valve covers... the plugs are below the exhaust manifolds... I cant see how the coil packs are in the way.. I can reach every plug but # seven with ease and the power brake booster is the problem with # seven....
Old Oct 20, 2003 | 06:56 PM
jimcork1's Avatar
jimcork1
Default Re: changing plugs (Evil-Twin)
I just changed my plugs to the iridum Bosch. They had the Bosch from Fact. The plugs were fairly easy to change I did buy the Snap-On Socket and it worked well. However the service from Snap_On was :U \
They charger about $49 (if I remember correctly) and $20+ for shipping the socket. :U
I ordered the boot puller also and it was BO. The cost was $15 for the Boot Puller and they shipped the wrong one and charged $20 for shipping. I returned the entire shippment and bought one at local parts house for $7.00
The snap-on socket does work well and I am glad I have mine but I would not order again from SO. :mad
Old Oct 20, 2003 | 09:54 PM
Evil-Twin's Avatar
Evil-Twin
Default Re: changing plugs (jimcork1)
It's 42 dollars off the truck.....
Old Oct 21, 2003 | 02:37 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
I took the coil packs off and even got the tough one out without any special tools.
Old Oct 21, 2003 | 09:44 AM
skidmarc's Avatar
skidmarc
Guys thanks for all the tips....doesnt that clip **** you off on the dvrs side? Helps to have a heavy bag hanging in the garage.....lol
I will have to look at it again with the coil packs off!
Who adjusts the gap by sliding the plug over the gage versus bends with gage/taps to close for gapping the plugs??? I have always just slid the plug along the gage till I reached the proper gap line...but was thinking last nite that it may mess up the electrode when wiggling it to get the gap since it was tight?
Old Oct 21, 2003 | 11:06 AM
Evil-Twin's Avatar
Evil-Twin
I bought Bosch Platinums.,.. the gap was protected with a cardboard collar... I checked all the gaps and they were perfect... I would not slide the gage to adjust the gap... I always use a "U" shaped tool at the base of the grounding electrode to bend it either way
Old Oct 21, 2003 | 11:01 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
I've changed my plugs about 5 times in the past 5 months. Buy the Snap On Swivel as discussed above. Use a 3/8" extension, either 18 or 24", and things become much easier. Start all plugs by hand and make sure you can spin them in 3-4 rotations - to prevent cross-threading. The Snap On swivel is great to help with threading in #5 and #7 plugs.....especially #7. Good Luck. :thumbs:
Old Oct 21, 2003 | 11:10 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
:cheers:
Ha, did not know this ... I actually just removed my coil pack and valve cover and it took me just 5 minutes ...
Thanks for the tip since I will replace my TR6 with TR55
:cheers:
Old Oct 22, 2003 | 05:24 PM
Evil-Twin's Avatar
Evil-Twin
Default Re: changing plugs (mike76002)
:cheers:
:cheers:
You removed the valve covers?????? why did you do that????
Or do you mean you removed the coil pack covers... ( the snap on plastic thingies that say Corvette...)
Old Oct 22, 2003 | 10:50 PM
SQEZN BI's Avatar
SQEZN BI
I just used a 3/8 swivel and a 10'' extension , that puts you past all hoses and stuff on the driver side rear plug which is the only one that was hard to get too. :D
To changing plugs
Old Oct 22, 2003 | 10:55 PM
0Vette Stripes
Former Vendor
:cheers:
:cheers:You removed the valve covers?????? why did you do that????
Oh, I just got a broken spring :cheers:
Old Oct 28, 2003 | 01:56 PM
skidmarc's Avatar
skidmarc
Vette.se,
I took your advice and removed the coil packs on the drivers side....wow how easy the job became....I only had an issue with the screw by the alternator mount....so I never put that one back in....figuring the other four are more than enough to hold the coil pack in place....Thanks for the tip bud!!! :seeya
Old Oct 28, 2003 | 02:09 PM
0Vette Stripes
Former Vendor
Vette.se,
I just replaced mine as well last Sunday and also removed the coil packs.
It was so easy but I did put that screw back ... should have kept it out.
