Synchromesh Equivalant?
Old Oct 21, 2003 | 06:56 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Synchromesh Equivalant?
Does anyone know what the Synchromesh equivalant is? I am putting a Tremec 5 speed in my 70 vette and did a search of the archives. C5s are the only place that are mentioned in the archives. SO, I thought I would ask you guys if you know the equivalant. I am thinking one of the Dextrons is the same as Synchromesh. Is this correct? Hopefully Dextron III is the same.
Thanks for any help you guys can give.
Old Oct 21, 2003 | 07:11 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Synchromesh Equivalant? (Eddie 70)
:yesnod: Yup. All the C5's with the six speeds come with (and specifically call for) Dexron III ATF. I am presently using Red Line's ATF and am very happy with it. Amsoil and Royal Purple brands also offer very good ATF's as well. HTH
Robert
Old Oct 21, 2003 | 07:19 PM
wwashing's Avatar
wwashing
The C5s manual transmission's recommended fluid is ATF (Automatic Trans. Fluid) that meets the Dex-III specification.
Most manual transmission require manual transmission fluid. I'd get in touch with Tremac and find out what they recommend. :cheers:
Old Oct 22, 2003 | 12:14 AM
Topless's Avatar
Topless
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06-'07-'08
Call Violater. He's got the RedLine fluid that goes in the MN6. He put it in my '03 a few weeks ago. Great stuff. :thumbs:
Old Oct 22, 2003 | 06:46 PM
vettenuts's Avatar
vettenuts
Default Re: Synchromesh Equivalant? (Topless)
The GM Synchromesh is a semi-synthetic fluid with different properties then the ATF that goes in the C5. Some have used it in the C5 for better shifting since it seems to do a better job with the syncrho's, however the long term effects are still unknown. Don't remember the other manufacturer's, but I can find out if you need it. You could also post in the transmission section on Bobistheoilguy.com for more technical information on these lubricants.
Here you go, start with this:
http://theoildrop.server101.com/ubb/...=000622#000000
[Modified by vettenuts, 7:11 PM 10/22/2003]
Old Oct 23, 2003 | 08:00 AM
RoadRebel's Avatar
RoadRebel
Default Re: Synchromesh Equivalant? (vettenuts)
Syncromesh is very different then Dex III. The Tremec 3550 you are using requires the Mesh..Penzoil now makes a Mesh equivalent available at most good parts stores for 1/2 the price of the GM version. We have used it for a while with good succes.
Phil
Old Oct 23, 2003 | 04:57 PM
Eddie 70's Avatar
Eddie 70
Thanks for the links. I bookmarked them for future use.
I broke down yesterday and went and bought some GM Synchromesh. $23 for 3 quarts. I almost fell out. Dextron III sure would have been cheaper though.
To Synchromesh Equivalant?
