Will disconnecting the AIR pump trip a code?
Old Oct 28, 2003 | 09:59 PM
BADNBLK's Avatar
BADNBLK
Default Will disconnecting the AIR pump trip a code?
I have installed headers and would like to disconnect the AIR pump and plumbing. Would the computer throw a code?
Old Oct 28, 2003 | 10:11 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Will disconnecting the AIR pump trip a code? (BADNBLK)
Yes it will, hope you dont have cats.
Old Oct 28, 2003 | 10:46 PM
BADNBLK's Avatar
BADNBLK
I have removed the cats and am presently using O2 simms. No codes yet.
Will the computer still throw codes?
Old Oct 29, 2003 | 02:43 PM
SFVetteman's Avatar
SFVetteman
The computer might throw codes. It uses the rear O2 sensors to see if the pump is working. I would just leave it hooked up as it only runs for a minute or two when a cold engine is started and doesn't effect performance.
[Modified by SFVetteman, 11:45 AM 10/29/2003]
Old Oct 29, 2003 | 03:52 PM
B. Stewart's Avatar
B. Stewart
As mentioned above it won't take any HP as it is an electric pump. It should throw a code if disconnected.
Old Oct 29, 2003 | 05:01 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Will disconnecting the AIR pump trip a code? (SFVetteman)
:iagree:
Kenny94945's Avatar
Kenny94945
Removing the AIR system is worth ten pounds.
Perhaps a resister or the like could fool the system so you could remove it and not get a yellow dash light?
To Will disconnecting the AIR pump trip a code?
