Shock Message
Old Nov 9, 2003 | 03:15 PM
BrawnyC5's Avatar
BrawnyC5
Cruising
Default Shock Message
I've been out of town for a couple of weeks at the fires in So. Cal. , when I got home I fired up the sorely missed 2001 vert and received a message that the shocks are not working and also a message of 159 MPH ?? There wasn't anything wrong when I parked it . Thanks.
Old Nov 9, 2003 | 03:33 PM
Tony M's Avatar
Tony M
Default Re: Shock Message (BrawnyC5)
Damn....Sounds like your wife had a great time with the Vette in your absence!!
Just wanted to say thanks for pitching in with the fires....It was all to real for me watching them burn from my front porch in the not to distant mountain tops!!
Try disconnecting the battery for 10 minutes and see if the same thing happens when you fire her back up....just a thought.
I'm sure someone out there has experienced this before and has a better idea what might be going on...
Good luck,
Tony M.
Old Nov 9, 2003 | 04:27 PM
BrawnyC5's Avatar
BrawnyC5
Cruising
Thanks Tony,
The wife did have a special little twinkle in her eye when I got back, and I thought it was me ! I'll try the battery disconnect, I was in the Piru , Stevenson Ranch area ( real close to you ) rebuilding the electric distribution systems. I was raised in SoCal and never have seen that much wide spread destruction. Thanks again.
Old Nov 9, 2003 | 05:05 PM
c5chris's Avatar
c5chris
So what was wrong with the C5? Did she 'fess up yet?
Thanks to you and your fellow FD guys. Here's to you :cheers:
To Shock Message
