Shut your TRAP
Old Nov 10, 2003 | 10:57 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Shut your TRAP
Actually, shut your hood on your TRAP Intake. Halltech's One time SALE on the Carbon Fiber TRAP in Candy Blackberry. We have a few in stock, and want them sold.
$580.00 for a limited time. Link to sale: http://www.corvettec5.com/store/?pag...a54889627204d8 (You must register as a forum member to "see" the forum pricing)
TRAP Electron Blue Carbon Fiber (Tunnel Ram Air Pak)
TRAP Carbon Fiber- 25% increase in airflow over the stock Z06 airbox/filter/bridge/accordion system. Testing was done by Dan Gurneys' AAR airflow guru on the Superflow flowbench. Our bottom section was designed by AAR for maximum flow. Our carbon fiber is pure autoclaved, pressurized bladder, vacuum bagged and cured under 100 PSI nitrogen at 290 degrees for hours. The internal finish is smooth. Halltech's first two delivered TRAP CF customers have made over 460 HP with the TRAP CF, tuning and exhaust mods. All bolt on mods! 714-899-3111 or Fax 714-899-3112 This is the exact intake used by Halltech to make their 382.2 RWHP/367.9 ft. lb. torque dyno pull with all stock Z06 exhaust! Available in Carbon Blackberry, Carbon Blueberry, 50th Anniversary Red, Stinger Candy Pomegranate Red. Integrated Carbon Hologram Logos are $20.00 additional. If you are trying to hit 400 RWHP with bolt-ons, this is the intake that will make it happen!
Price: $649.00 Retail.
Forum Price: $580.00 (Carbon Blackberry Only)
Here is a picture of our Carbon Blueberry TRAP CF complete. We don't have a good picture of our Blackberry, except these individual pictures:
Jim Hall http://www.corvetteC5.com
Old Nov 11, 2003 | 06:18 AM
cmeflyby's Avatar
cmeflyby
From: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
Default Re: Shut your TRAP (Jim Hall)
Is there any color to this "Blackberry" model? I can't tell from the pics here or on your website for sure. It looks like regular graphite colored carbon fiber to me. Is that what it is?
I was thinking, did you guys try running a Blackwing filter on this? Hard to be sure from the pics but this filter looks to be smaller and the slanted surface of the Blackwing would put just a little bit more "contact" area of the filter exposed to the air coming in from the tunnel port... 1 more HP? :rofl:
Thanks. :cheers:
By the way, your EB colored setup is sooooo :cool:
Old Nov 11, 2003 | 07:23 AM
kumar75150's Avatar
kumar75150
Default Re: Shut your TRAP (cmeflyby)
I want that blue one but I already have a Vararam and cf air bridge.
That thing looks sweet.
Old Nov 11, 2003 | 12:00 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Our surface area is 25% larger than the Blackwing. Flowbench results show 7% greater flow.
That really does not make much difference in the real world since the volumetric efficiency increase is the first part of the power equation, with the second being cold ram air.
The Blackwing sucks hot air. At 95-degrees IAT, the Blackwing will lose 1 degree of timing. At 135-degrees a full 12 degrees is pulled on the LS1 which equals 10 RWHP.
Our TRAP breathes ambient air from the front facia through the Warhead filter, thus preserving full timing.
In the real world, the Blackwing will be at least 10 RWHP behind the TRAP at all times.
Check out this dyno done by our distributor 21st Century Muscle Car:
This was done with our TRAP, a cooler thermostat, and LS1 Edit Programming. 27 RWHP.
Jim
Old Nov 11, 2003 | 10:45 PM
Dave68's Avatar
Dave68
Jim
Jim,
I've seen some Blackwing installs and can see why they draw in hot air. When you say that the Trap breathes ambient air from the facia, does this mean that the air comes in from an opening that you must create? I guess I'm not sure what the facia is. Do you have any pics of the unit already installed?
Old Nov 11, 2003 | 11:00 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Shut your TRAP (Dave68)
I beleive it comes through the front plate location. The were pictures, try a search in ZO6 section
Old Nov 11, 2003 | 11:09 PM
Dave68's Avatar
Dave68
Default Re: Shut your TRAP (John Shiels)
I guess that if you didn't want to remove your front cover, having screens in place of the fog light plates is still better than having a Blackwing with no screens?
Old Nov 12, 2003 | 04:14 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
This is where the Warhead filter is placed. This cutout is only done with our Stage II Tunnel Port modification.
On the LS1, the front bumper (facia) is not a vacuum box, thus all of the air within that area is ambient. Obviously, the Z06 screens or our Tunnel Port make our TRAP much more funtional.
The Stage 2 Tunnel Port creates a Ram Air effect, but is not True Ram Air.
Jim
Old Nov 12, 2003 | 04:17 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Exactly. The Blackwing must breath hot air due to its placement. We have recorded a delta of over 40 to 50 degrees difference at the Intake Air Temp sensor between underhood breathers and our TRAP. In fact, at idle, our IAT was within 9 degrees of ambient, and the moment the car began movement the IAT dropped instantly to witin 3 degrees of ambient. By one block the temps were in parity.
Old Nov 12, 2003 | 06:07 AM
vettenuts's Avatar
vettenuts
Rats, if only you had extra of the POM Red (that matches the Mag Red II) :cry
Old Nov 12, 2003 | 06:41 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Shut your TRAP (vettenuts)
How exactly does the TRAP differ from your old TRIC? They look pretty similar at first glance.
That is, other than the difference in carbon fiber and price.
I'm curious as to what performance improvements have been made since I can pick up a TRIC for $150 that looks no different to the naked eye. :yesnod:
[Modified by BQuicksilver, 6:42 AM 11/12/2003]
[Modified by BQuicksilver, 6:50 AM 11/12/2003]
Old Nov 12, 2003 | 03:02 PM
EFI-1's Avatar
EFI-1
Jim, any chance you'll do a special on the red c/f TRAP?
Old Nov 13, 2003 | 10:53 AM
Heretic's Avatar
Heretic
Blackberry??? , are these Imacs or car parts?
:thumbs: just joshing.
Old Nov 13, 2003 | 03:45 PM
Dave68's Avatar
Dave68
Jim
Thanks, Jim - great explaination! It looks like I need to get a TRAP and more air through the fog light areas. :cheers:
Old Nov 13, 2003 | 08:51 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Jim I called the number you left me in one of your other posts and left you a voice mail. I already have a vortex and am wondering what the sale price (if there is one) is on just the upper power duct part in black carbon fiber w/ the Z logo. Thanks.
Old Nov 14, 2003 | 01:24 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Re: Shut your TRAP (Cobra4B)
The link to our Carbon Fiber Tunnel Bridge:
If you Login as a Forum Member, the pricing will automatically show $319.00
Old Nov 14, 2003 | 01:44 AM
EFI-1's Avatar
EFI-1
Jim, where is your pricing on the website for the Pomergranate TRAP? I found the airbridge and FRC's, but I want the TRAP & FRC's....
I'll be placing my order through Nate at the Corvette Garage this week.
Thanks , Dave
To Shut your TRAP
Old Nov 14, 2003 | 01:51 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Re: Shut your TRAP (EFI-1)
http://www.corvettec5.com/store/?pag...e4314bf694cc1c
Old Nov 14, 2003 | 02:00 AM
EFI-1's Avatar
EFI-1
Jim this looks like just the airbridge & FRC's...or does it also include the lower portion of the TRAP with the warhead filter? I'm looking for the whole thing.
Old Nov 14, 2003 | 05:39 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
The retail price for just the Candy Pom Red TRAP is $649.00.
I gave pricing to Nate for you.
Jim
