Cat removal?
Old Nov 12, 2003 | 06:59 PM
jmzvet's Avatar
jmzvet
Default Cat removal?
If I remove the Cats from my 03, install some O2 sims and straight pipes, is there anything else to be concerned with ( other than smog issues )?
Old Nov 12, 2003 | 07:37 PM
larrysb's Avatar
larrysb
Default Re: Cat removal? (jmzvet)
The smell.
Get it dyno tuned, pulling the cats will make a significant change in the dynamics at the valve overlap time. The only way to compensate is by editing the PCM and tuning it on a dyno and monitoring the mixture.
For various good and valid reasons, I'm against removing the catalyst on a highway vehicle. If you find youself overhwelmingly horny to do this for some reason, then do it properly.
Old Nov 13, 2003 | 10:13 AM
6Speeder's Avatar
6Speeder
Default Re: Cat removal? (larrysb)
:iagree: When you add the cost of the parts, and the cost of proper tuning, it's a pretty poor cost/benefit ratio. Add in the grief from your neighbors because of the freekin' NOISE and the added pollution I just don't see it as worthwhile for a street driven car.
:nono:
[Modified by 6Speeder, 8:14 AM 11/13/2003]
Old Nov 13, 2003 | 12:03 PM
carpe dm's Avatar
carpe dm
:iagree: If you are not an all out track racer, why would you do this? Very little to gain except fines and/or jail time. :conehead Obviously, most people think they won't be caught and don't care about the polution angle, but it is a felony. :yesnod:
[Modified by carpe dm, 10:05 AM 11/13/2003]
Old Nov 13, 2003 | 12:39 PM
denali's Avatar
denali
St. Jude Contributor
Do Not Remove
Old Nov 13, 2003 | 03:37 PM
C5JONNY's Avatar
C5JONNY
The car gets very loud! Or so I've been told :leaving:
Old Nov 13, 2003 | 05:50 PM
ForceFedC5's Avatar
ForceFedC5
Don't do it.. not worth the power.. and it stinks..
There are MANY other ways to go if you are looking for the power and/or sound.. :cheers:
Old Nov 13, 2003 | 07:39 PM
jmzvet's Avatar
jmzvet
Default Re: Cat removal? (MyFirstCorvette)
Good info from all :cool: . Thanks :cheers: .
To Cat removal?
