Do new spings need breaking time?
Old Nov 20, 2003 | 01:55 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Do new spings need breaking time?
I just swapped REV springs to Isky springs.
Do they need breaking time?
:cheers:
[Modified by mike76002, 12:55 PM 11/20/2003]
Old Nov 20, 2003 | 02:34 PM
MTWallet's Avatar
MTWallet
Default Re: Do new spings need breaking time? (mike76002)
It is highly recommended with any new spring to heat cycle them to help with the temper of the spring. Just bring the engine to temp and then let it cool down completely. Do this a few times and you're all set to go. I cycled mine 3 times to be on the safe side.
Old Nov 20, 2003 | 02:51 PM
0Vette Stripes
Former Vendor
Default Re: Do new spings need breaking time? (MTWallet)
Mike, long time no see you on the forum :D
Thanks for the tips.
:cheers:
Old Nov 21, 2003 | 10:09 AM
RoliO's Avatar
RoliO
:cheers:
We can break them in when we race this weekend. :D
Old Nov 21, 2003 | 10:50 AM
BlueBlazer's Avatar
BlueBlazer
[QUOTE]I just swapped REV springs to Isky springs.QUOTE]
Mike,
Sorry to break off topic. but why did you change to the Iskey's? and was the valvetrain quieter than your REV's with them?
Old Nov 21, 2003 | 11:53 AM
Patches's Avatar
Patches
Default Re: Do new spings need breaking time? (BlueBlazer)
:lurk: Which spring compressor tool did you use? Are they dual springs? Any machining to the spring seats required for these? What was the install height?
Old Nov 21, 2003 | 12:14 PM
RoliO's Avatar
RoliO
Mike,
I believe he broke 2 REV's within a month or so. So he changed them out. :cheers:
Old Nov 21, 2003 | 12:20 PM
0Vette Stripes
Former Vendor
Default Re: Do new spings need breaking time? (RoliO)
Mike,
:withstupid:
I replaced with Isky Double springs and using a really cool valve compressor tool that only costed 30$. Check my other post for that tool.
Well, it is still as noisy as REV and you need to use new seats and retainers.
[Modified by mike76002, 11:21 AM 11/21/2003]
Old Nov 21, 2003 | 01:52 PM
MTWallet's Avatar
MTWallet
Mike,
Why did you go with the Isky's instead of the new Crane Duals?
[Modified by MTWallet, 12:52 PM 11/21/2003]
Old Nov 21, 2003 | 04:24 PM
0Vette Stripes
Former Vendor
Isky's are also dual and I have heard many good review about them ... people even told me that Isky warranties their spring for 10K miles up to .65 lift. Another thing was it only costed me 100$ to swap.
I don't know how much for Crane Duals.
Mike,
Old Nov 22, 2003 | 12:13 AM
gary brown's Avatar
gary brown
From: Los Angeles Founder, West Coast Corvette Challenge
Mike - what retainers are you using and how much for the Isky valve springs?
Old Nov 22, 2003 | 11:28 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
i would use comp cams "spring spray" on the springs so when you start the engine for the first the spring are lubed because till the oil get to them they can get very hot. i watch a dyno test were they cut off the oil supply to the springs and in less than 30 seconds the exhaust spring were glowing red. this lead to the development of the "spray bars" inside the rocker covers for NASCAR engines. the "G" forces in the turn was causing the oil not to reach the springs and cook the life out of them. this overheating no matter how small could be the cause of valve spring failure
[Modified by clem zahrobsky, 11:29 PM 11/22/2003]
Old Nov 23, 2003 | 06:05 PM
MTWallet's Avatar
MTWallet
Default Re: Do new spings need breaking time? (clem zahrobsky)
Clem is right but you don't have to spend money on the spray. Just get a quart of Mobil 1 (or whatever oil you are using) and pour it slowly over the rockers and springs after everything is installed. I use a small 1-pint pump oil can with a flexible spout and squirt inside the springs to be sire the valve stems 7 seals are well lubricated too (especially with new heads).
Old Nov 23, 2003 | 07:28 PM
0Vette Stripes
Former Vendor
Thanks guys ... but too late now ... I already fired it up the other day ...
Should have done it tho
Old Nov 23, 2003 | 07:35 PM
pdd000's Avatar
pdd000
good luck mike :cheers:
Old Nov 23, 2003 | 07:43 PM
2001 Red Coupe Bandit's Avatar
Default Re: Do new spings need breaking time? (pdd000)
yep heat cycle the car 2 or 3 times. I just heat cycled mine 2 times so when i get the rest of my car done Monday I am ready to go :yesnod: :party:
To Do new spings need breaking time?
