Stupid fuse question???????
Old Dec 2, 2003 | 08:43 PM
Walford's Avatar
Walford
Default Stupid fuse question???????
I blew the HVAC fuse yesterday (or so it seemed -- the A/C went dead), and yanked that insufferable passenger floor panel off, tinkered with the fuses for a minute and swapped the "SCM-L" fuse with the "HVAC" fuse (both 10-amp) to see if the fuse was the problem. Apparently it was, because the A/C fired right up.
Now, what the heck did I disable????? I can't figure out what fuse #4, SCM-L, is. :confused: Every electronic gizmo works as it should. What the heck is an "SCM-L?"
Before you smack me over the head with the obvious, I can't get to my owner's manual; it's packed away. ;)
Thanks for any help.
Old Dec 2, 2003 | 09:10 PM
bowtiebandit's Avatar
bowtiebandit
Default Re: Stupid fuse question??????? (Walford)
SCM...Seat Control Module
Old Dec 2, 2003 | 09:14 PM
Wt99C5's Avatar
Wt99C5
Default Re: Stupid fuse question??????? (bowtiebandit)
:yesnod: supplies power to the relays that controls the seats motors
Old Dec 2, 2003 | 09:26 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
:yesnod: :yesnod: :iagree: :thumbs:
Old Dec 3, 2003 | 09:14 AM
Fast one's Avatar
Fast one
When you replace fuses use the new kind that has an led built in; they cost more but a blown fuse will light up.
Old Dec 5, 2003 | 04:05 PM
Walford's Avatar
Walford
:confused: That's what I thought, but when I switched the 2 fuses BOTH seats still work.
Of course, my lighter stopped working about a day later (it worked fine that day.)
Damn Corvette electrical ghosts! :rolleyes:
To Stupid fuse question???????
