C5 Transmisson/Differential Concerns
Old Dec 16, 2003 | 10:54 PM
CLHaka's Avatar
CLHaka
Default C5 Transmisson/Differential Concerns
Anyone have the procedure for refilling the transmission fluid on a FLP A4 tranny?
Also, how much power can a stock differential withstand drag racing 3500 stall and et streets?
What is the bullit proof recommendation for the diff? Also, what is the most common driveline brakage with 550 or more RWHP? :grouphug:
halfshaft twisted anyone?
thx....
Old Dec 17, 2003 | 02:36 AM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Re: C5 Transmisson/Differential Concerns (CLHaka)
Get in touch with VStella. He is the A4 mod guru!
Old Dec 17, 2003 | 11:03 AM
TLewis4095's Avatar
TLewis4095
If filling from dead empty replacement pour 1 quart in TC before installing and fill tranny through side fill hole (after all is back in car) untill it runs out. Start the car and run for 1-2 minutes. Shutoff & refill until fluid runs out. Restart and gradually fill until fluid begins to spill out the side fill hole. Should be full. Goes without saying but make sure car is supported by jack stands and is fairly level. Drive around and re-check same way.....with car running in park & fluid up to the side fill hole. :cheers:
Old Dec 17, 2003 | 11:16 AM
carpe dm's Avatar
carpe dm
Default Re: C5 Transmisson/Differential Concerns (TLewis4095)
Once you have filled the trans, REPLACE THE PLUG (finger tight) before running through the gears and getting ready to top it off. With the car running, remove the plug and add necessary fluid to bring it to the top of the hole (until some runs out), then replace the plug. :yesnod: :)
Old Dec 17, 2003 | 12:03 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: C5 Transmisson/Differential Concerns (carpe dm)
If filling from dead empty replacement pour 1 quart in TC before installing and fill tranny through side fill hole (after all is back in car) untill it runs out. Start the car and run for 1-2 minutes. Shutoff & refill until fluid runs out. Restart and gradually fill until fluid begins to spill out the side fill hole. Should be full. Goes without saying but make sure car is supported by jack stands and is fairly level. Drive around and re-check same way.....with car running in park & fluid up to the side fill hole. :cheers: Once you have filled the trans, REPLACE THE PLUG (finger tight) before running through the gears and getting ready to top it off. With the car running, remove the plug and add necessary fluid to bring it to the top of the hole (until some runs out), then replace the plug. :yesnod: :)
:iagree: :thumbs: :cheers:
Old Dec 17, 2003 | 01:40 PM
CLHaka's Avatar
CLHaka
Thanks everyone! I will do! :thumbs:
Old Dec 17, 2003 | 09:52 PM
CLHaka's Avatar
CLHaka
OKAY! Update , I just received my Feb. 2004 ISSUE of Chevy HighPerformance MAG. (still in love with the first gen Camaros), By the way I have a MINT TRUE 1968 SS with a 519 HP 406 for sale) Anywho, in this issue there is a article on a LS-1 in a Z-28 THAT RUNS 8.54@ 168 with spray.
SOMEONE SAY :cool:
CHECK IT OUT!
Sorry FOR THE RAMBLE, the article mentions that Stevens@ Canada's Agostino Racing Engines (ARE) Will start development of rearends and trannys that will survive "EXTRAORDINAY POWER" :party:
Thanks to all that support the best site on the web....CORVETTEFORUMNS.COM! :hurray:
To C5 Transmisson/Differential Concerns
