My factory fluid is at 25K miles and shifting is feeling a little more difficult lately. I was thinking about jacking the car up tonight and swapping with Redline ATF. How hot will this fluid come out if I am driving the car today? Should I let the car cool for several hours then do the flush/fill, or is it not even a problem?
My friend you asked about the diff fluid then you say you are going to change with redline ATF, I would think that you ment the tranny. I would let it cool for at least 30 mins.
I wanted to let you know that your instructions were very helpful. Also, it appears my 2002 C5 is slightly different than your Z06. For my gearbox, the fill plug and drain plug were both 3/8" drive socket type plugs. Also, the fill plug did not have any kind of electrical connector going to it. I could see there was a sensor mounted near it, but nothing actually on it. I triple checked that this port was marked "fill" before putting anything in it :lol:
I'll send you an IM so you can include this info in your write up. I am not sure if it's a Z06 vs C5 thing or a 2002 and up thing.
Thanks! The Z06 has the tranny overheat sensor there and the coupe/vert does not. I will try and change it soon.
