pcv mod q?
Old Dec 29, 2003 | 03:29 PM
skidmarc's Avatar
skidmarc
Default pcv mod q?
Anyone have this mod with oil accumulated in the lil clear container and actually have less oil in it the next time you checked it??? Possible to get sucked back thru filter??? I checked and the bottom has no signs of leaking :confused:
Old Dec 29, 2003 | 10:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: pcv mod q? (skidmarc)
Some of it could have beem water and it evaporated!? I have had mine installed for about 3 months and there is only about 1/4 oz in the tube! Engine must be runnen GOOOOD!!! :thumbs:
BC
Old Jan 3, 2004 | 02:48 AM
skidmarc's Avatar
skidmarc
ttt
Old Jan 3, 2004 | 06:44 AM
markcz's Avatar
markcz
I noticed on mine that it takes about a week for the level to fill to about 1/4" deep in the filter. If I empty the filter it will refill to the same level in another week. If I DON'T empty the filter, the level never changes from the 1/4" that was there after a week. I've gone about 2 months without draining it and it never went above 1/4", but as soon as it's emptied the oil comes back in about a week. :confused:
:cheers:
Old Jan 3, 2004 | 08:49 AM
racetchr's Avatar
racetchr
Default Re: pcv mod q? (markcz)
Mine is same.
:iagree:
Old Jan 3, 2004 | 06:51 PM
skidmarc's Avatar
skidmarc
yeah I noticed the same....any physics/chemistry majors that can explain this???? I would think it has to do with pressure??? I know its not leaking out of the bottom thru the relief valve..hmmmm :confused:
Old Jan 3, 2004 | 08:44 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
________________________________________ ________________________
Same here, 1/4 inch and no more, I am using the Campbell Hausfeld filter without the inner filter. I cut the bowl down to make it smaller
Old Jan 3, 2004 | 09:10 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Re: pcv mod q? (vette#one)
I wonder if the temp of the air going through the reservoir is only allowing it to fill to a certain level. Maybe if the reservoir was deeper it would make a difference. :thumbs: :seeya
Old Jan 3, 2004 | 10:50 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: pcv mod q? (Stock Man)
Man,,, that is weird! I have the same 1/4 of oil in mine! I will dump it out and see what happens.
I guess this is a case of "The things hhat make ya go Hmmmmmm!"
Bill
Old Jan 4, 2004 | 11:31 AM
6SPD98's Avatar
6SPD98
Default Re: pcv mod q? (Bill Curlee)
I guess this is a case of "The things that make ya go Hmmmmmm!"
Hmmmmmmmmmm :D :D :D
Old Jan 4, 2004 | 02:38 PM
MTWallet's Avatar
MTWallet
Here is a pic of my catchcan that I made myself: (there is a foam filter rolled up inside to soak up the airborn oil mist)
I check it every few weeks and only get a few tablespoons of oil each time. Maybe I will let it go for a month or longer and see if the amount increases.
[Modified by MTWallet, 1:40 PM 1/4/2004]
Old Jan 4, 2004 | 04:57 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: pcv mod q? (MTWallet)
Well,,,,,,,,,,,,for those of you that think that the oil is being sucked back out, give this a shot! Fill it with clean oil to a level higher than the 1/4" mark (say 1/2 - 3/4" level) and reinstall the bowl. Drive it for a week and see if there is MORE or LESS oil. :thumbs:
That should solve that theory!
Bill Curlee
Old Jan 6, 2004 | 05:04 PM
skidmarc's Avatar
skidmarc
professional looking mod bud!! :cheers:
To pcv mod q?
