Car wouldn't start ??????
Old Dec 30, 2003 | 12:01 AM
RJ98Vette's Avatar
RJ98Vette
Default Car wouldn't start ??????
Leaving work tonight I put the key in and when I turned it, there not no response. The DIC and stereo turned on as well as exterior lights, but no ignition. I tried removing the key and starting in neutral, both of which didn't work. I managaed to get it to turn over, but it wouldn't stay running.
Finally it fired and ran fine all the way home.
Any ideas what could be wrong? :confused:
Old Dec 30, 2003 | 01:49 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Re: Car wouldn't start ?????? (RJ98Vette)
you could have a problem and then maybe not. the c5 can do some strange things one time and never duplicate it again.
The first thing to do is check for codes.
Old Dec 30, 2003 | 06:57 AM
C5XTASY's Avatar
C5XTASY
Insert and withdraw your key several times into the ignition switch cleaning the key with alcohol in between insertions. This same exact thing happened to me after eating a jelly doughnut. Must have had something on my fingers when I grabbed the keys out of my pocket. I learned my lesson. I didn't know what was going on either. Stay away from Krispy Kremes! :lol:
Ed
Old Dec 30, 2003 | 10:37 AM
RJ98Vette's Avatar
RJ98Vette
Default Re: Car wouldn't start ?????? (C5XTASY)
Thanks. I will try and check the codes next. It ran fine this morning and started fine both times - first at 4 AM when I stopped worrying and got up to try it and then again at 6AM leaving for work.
To Car wouldn't start ??????
