Stroker ??
Old Jan 8, 2004 | 07:12 PM
hogurt's Avatar
hogurt
Default Stroker ??
I am looking at stroker kits for a SC'd motor. Let's say I am going to stick with stock heads and add an LS6 cam. . .
a. Should I also have the bore increased?
b. What is the MAX one can increase stroke on a stock LS1?
Finally, does anyone know the formula for calculating Cu. in? What are the stock LS1 statistics (stroke and bore)?
Old Jan 8, 2004 | 10:19 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: Stroker ?? (hogurt)
I hear an all bore motor is the ticket for lots of high RPM driving, but the high bore and long stroke seems to work fine for the C5-R!
One day I'll have a 427 in the Z. :cheers:
[Modified by Cobra4B, 10:20 PM 1/8/2004]
Old Jan 8, 2004 | 10:26 PM
FreddyG's Avatar
FreddyG
This is just my opinion, but for the money that you'll spend on a stroker, would you get more performance putting that towards heads, rods (or at least ARP bolts), pistons, and then turn up the boost? Just my .02, and usually you get what you pay for! :D
Old Jan 8, 2004 | 10:49 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
You can bore (or resleave) the c5r block to 4.155 (no sure about a resleaved block but I think its the same) I have heard of a few guys going with a 4.250 stroke but have heard no success stories, most go with a 4.0 for a higher reving engine my 436ci is a 4.125 stroke and a 4.1 bore, I could have gone 4.125 on the bore (441ci) but it is really pushing as there is virtually nothing left between the cylinders. I simply wanted an NA car without the plumbing etc my blower motor put out more power even at low boost---
Old Jan 8, 2004 | 11:01 PM
hogurt's Avatar
hogurt
Default Re: Stroker ?? (NEPTUNEBILL)
Well, to be very clear. . .
Instead of purchasing forged parts for the stock engine, I can buy a stroker package for the same (or less) and it too consists of all forged parts. . .
From what I can tell, there is NO advantage to staying at 350cu.in. Instead, I may as well add a stroker package (w/ no bore) and pick up the extra inches.
In case I wasn't clear, the SC is staying. I will continue to run boost (of course with forged internals, I can up the boost).
Old Jan 9, 2004 | 12:07 AM
fast 98 C5's Avatar
fast 98 C5
I have a 4.25 stroke and I'm OK !
Cubes are king !
Old Jan 9, 2004 | 12:09 AM
FreddyG's Avatar
FreddyG
Gotcha! Best of luck to ya! :cheers:
Old Jan 9, 2004 | 12:28 AM
hogurt's Avatar
hogurt
Default Re: Stroker ?? (fast 98 C5)
Do you have a stock bore?
What's the largest stroke possible with a stock LS1?
Old Jan 9, 2004 | 06:18 PM
UAWDES1's Avatar
UAWDES1
My .02, Watch yourself in as far as increasing your stroke too much. As your stroke increases so does the angle of your connecting rod to wrist pin center. That's a lot of stress on the rods and pins. Kinda like pushing more sideways on the piston versus up and down. Strokers give you more torque than horses and as they say "Torque is what gets you down the road" :thumbs:
Again my .02
KJ
Forgot to mention to watch your compression ratio also. Too much compression as I have or more and the S/C loses its worth. .02 more!
[Modified by UAWDES1, 6:22 PM 1/9/2004]
Old Jan 9, 2004 | 06:34 PM
fast 98 C5's Avatar
fast 98 C5
Default Re: Stroker ?? (UAWDES1)
Some things you might want to consider.
Some resleved blocks have had problems in high boost and N2o applications.
You can use a steel block 6.0 and go with a 4, 4.030, or 4.060
You can use a stock stroke or 4, 4.125, or up to 4.250.
This can give you 408-434 stroker.
Man with boost that should be a beast !
Good luck !
Old Jan 9, 2004 | 06:36 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
[QUOTE]I have a 4.25 stroke and I'm OK ! :eek: :eek: :crazy: :crazy:
Old Jan 9, 2004 | 08:17 PM
hogurt's Avatar
hogurt
Default Re: Stroker ?? (MTI 427 Roadster)
I appreciate all of the input, but I really don't see an answer to my question.
What is the max stroke I can run with a stock block and NO bore? Once I see how many cubes I can get with stroke only, I will determine if I also need to bore the block.
Thanks,
R
Old Jan 9, 2004 | 09:05 PM
JakeL's Avatar
JakeL
Thanks,
R
The max stroke that is commonly run is 4.125", but motors built on a stock bore (or even with a 4" bore and larger) seem to be more prone to oil burning problems and other issues. It also requires a bit of clearancing to the block, if I remember correctly. This would give you 395cid on a stock bore engine.
Much more common, and virtually trouble-free, it seems, is a 4" stroke. on a stock bore, that would give you a 382 cid engine.
Here is a list of some common combinations: http://www.jakelatham.com/c5/misc/faq.shtml#1-15
a C5R uses a 4.125" bore, with a 4" stroke for 427ci.
You calculate bore using the formula for the area of a cylinder. pi*radius^2 * height.
so, that's 3.141 * (bore / 2)^2 * stroke
then multiply by number of cylinders = 8.
-Jake
[Modified by JakeL, 7:06 PM 1/9/2004]
Old Jan 10, 2004 | 05:46 PM
Mopar Jimmy
St. Jude Donor '06
Default Re: Stroker ?? (JakeL)
[QUOTE]I appreciate all of the input, but I really don't see an answer to my question.
Thanks,
R
-Jake
Great info from JakeL and i agree with him 1000%!!! :iagree:
Old Jan 10, 2004 | 06:05 PM
don7790's Avatar
don7790
The easiest way to calculate the CI is Bore sq * stroke* .785* # of cyl's=CI
Old Jan 10, 2004 | 10:07 PM
hogurt's Avatar
hogurt
Default Re: Stroker ?? (don7790)
This is great news. This means I can go with a 382 stroker (kit) and I should only need a few more things (like a fuel pump and larger injectors) to have my car back on the road.
Any guesses as to the HP on a 382 w/ stock LS1 heads, LS6 cam and 10psi?
This will be an interesting experiment! :thumbs:
Old Jan 10, 2004 | 10:31 PM
Mopar Jimmy
St. Jude Donor '06
I'll take a stab at it and say that you should be putting down a solid 500rwhp but considerable more if you would match the proper heads and cam to work in perfect harmony with the big cubes and 10psi. :cheers: :crazy: :chevy :flag
Old Jan 11, 2004 | 12:51 AM
HIGHRPM's Avatar
HIGHRPM
The C5R block comes unhoned at 4.117" and can be safely bored to 4.160...doesn't need resleeving. With a 4.155" bore and a 4.155 stroke (Hank 's E4340 Billet crank) 6.125" rods gives almost 451 ci. Cylinder deck height is 9.240" This motor was recently built up in October Chevy High Performance Mag and made over 575 lb-ft of torque on gas. :cheers:
[Modified by HIGHRPM, 9:53 PM 1/10/2004]
Old Jan 11, 2004 | 08:15 PM
hogurt's Avatar
hogurt
I am thinking around 500-550rwhp with stock heads, cam and stock manifolds. Unfortunately, the fiance is limiting my winter project expense! :rolleyes:
Next winter, LT's heads and custom cam. . . :thumbs:
To Stroker ??
