shift boot
Old Jan 11, 2004 | 12:06 AM
DelMonteZO6's Avatar
DelMonteZO6
Default shift boot
I am going to shorten my shifter. Before I go start taking the cosole apart . Does anyone know if the shift boot just pops off? Or do I have to remove the consloe?
Old Jan 11, 2004 | 12:30 AM
HIGHRPM's Avatar
HIGHRPM
Default Re: shift boot (DelMonteZO6)
It has clips around the inside edge.....push down gently and it comes right out.....but since your changing the shifter the console has to come out anyway. :cheers:
Old Jan 11, 2004 | 12:33 AM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Default Re: shift boot (HIGHRPM)
:iagree: You have to remove the **** TOO.
[Modified by ALLKAR, 11:34 PM 1/10/2004]
Old Jan 11, 2004 | 02:56 AM
Lancer033's Avatar
Lancer033
Default Re: shift boot (ALLKAR)
:iagree: just grab a couple of screw drivers and pry the demon key up, some people have trouble with this, but mine came out w/o any trouble. Removing the interior is pretty easy, there is a how to somewhere on the forum
good luck
Edit: these might help https://www.corvetteforum.com/techti...D=34&TopicID=1 https://www.corvetteforum.com/techti...D=28&TopicID=1
[Modified by Lancer033, 2:00 AM 1/11/2004]
Old Jan 11, 2004 | 03:17 AM
DelMonteZO6
Default Re: shift boot (Lancer033)
Thanks for thew help guys. I was going to try this http://joshker99.home.comcast.net/shifterpage.htm
but Im opting against it. Im gonna either go with the breathless performance or the B&M. And youre right on the vette essentials site they give dirsctions on how to remove console and shifter and they say its really hard to remove the **** but it took me like 30 seconds. There is a little lip on the key you can just get a good size flathead and pry it out. :skep:
To shift boot
