Sway Bars 101
Understeer ("push" or "tight") or oversteer ("loose") can be adjusted by how much of the roll resistance is done by the front suspension and how much by the rear.
Anti-roll bars, popularly called sway bars, are used for tuning the handling by adding roll stiffness to front and or rear. Using A/R bars allows softer springs.
Bigger (stiffer) A/R bar in front increases the % of front roll couple and tends to make the car "push" or be "tight" or understeer. Bigger rear tends to "loose" or oversteer. It's important to have a balance, and to have understeer at the traction limit.
Because the A/R bar interconnects left and right wheels, there is some reaction over one-wheel bumps. Most OEM or even aftermarket bars are not stiff enough to make the ride very bad, but you may feel them.
No such thing as no body roll in almost any production or even race car. Stiffer springs and A/R bars reduce roll, but don't eliminate it. Cornering at 1g in a stiff car could give maybe 3 degrees of roll. Obviously .5 g on ramp driving would be half of that, which feels pretty flat.
:cheers:
What's the difference between Z06 sways and Hotchkiss? Why did you go with Hotchkiss over other brands?
http://forums.corvetteforum.com/zerothread?id=730617 :cheers:
