Brakes
Old Jan 24, 2004 | 12:08 PM
ltnate's Avatar
ltnate
Default Brakes
Has anyone used the Reybestos Brutestop rotors? They are slotted/drilled and only cost around $90.
Old Jan 24, 2004 | 02:25 PM
gmblack3's Avatar
gmblack3
Default Re: Brakes (ltnate)
check rockauto.com
Old Jan 24, 2004 | 02:52 PM
Richin Chicago's Avatar
Richin Chicago
The usual warning. Slotted rotors don't do much, other than wear out pads faster. Older pads produced a lot of gas and the slotted rotors helped pump it away. Not much of a problem anymore.
Drilled rotors have a tendency to crack if you are planning on any track days.
On the other hand, for show, I love drilled rotors.
As mentioned above the brutestop are only half the price you posted at http://www.rockauto.com
[Modified by Richin Chicago, 1:55 PM 1/24/2004]
Old Jan 25, 2004 | 02:37 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: Brakes (Richin Chicago)
:iagree: :iagree:
Old Jan 25, 2004 | 09:21 AM
vettenuts's Avatar
vettenuts
Are the Brutestop Zinc washed? I am looking for something that won't rust.
To Brakes
